Sub SVC + DVC = ? ohm’s
Vuthyma
Posted: March 03, 2004 at 6:07 AM / IP Logged
WHAT'S THE OHM'S FOR 1 SVC 4 ohm + 1 DVC 4 ohm = ??.  COULD I GET 3 ohm with 2 subwoofer?
DYohn
Platinum - Posts: 10,741
Posted: March 03, 2004 at 10:27 AM / IP Logged
Do you plan to run them both off of one amp?  That is not a good idea, as the sub with the lower impedence will utilize more power and be louder.  Always match subs when hooking them up together,.
Vuthyma
Posted: March 04, 2004 at 4:07 AM / IP Logged
WELL, I GOTTA GO UNHOOK MY CAR SYSTEM.  THANKS FOR THE WARNING.  THAT'S WHY I CAN'T FIND ANY INFOR RELATE TO HOOKING UP SVC & DVC FROM ANY MANUFACTURERS.
COULD I HOOKUP TOGETHER USING  1 SVC 8 ohm's SUB & 1 DVC 4 ohm's SUB????
DYohn
Posted: March 04, 2004 at 8:22 AM / IP Logged
Yes, as along as the impedence of each sub is equal (meaning wiring them both at 8 ohms) then connect to the amp in parallel for a net 4-ohm load on the amp.
