Hood pin switch not setting off alarm
phamine
Copper - Posts: 88
Posted: June 29, 2003 at 7:39 PM / IP Logged
My doors and trunk are setting off the alarm. The pin switch for the hood is not setting the alarm off though. I did replace the pin switch and remounted it in the middle of the hood near the firewall.
My original pin switch was held on by a metal plate and then attached to the car. Right now the switch is mounted on plastic. Should I use a metal plate to mount the switch?
Platinum - Posts: 12,488
Posted: June 29, 2003 at 7:45 PM / IP Logged
Yes, the hood pin switch has to see ground ( metal ) when it is in the up position.
phamine
Copper - Posts: 88
Posted: June 29, 2003 at 8:25 PM / IP Logged
Thanks for the tip. I'll try to ground it tommorrow and take some pics of the location where I have it mounted. Would you be able to help me with this question?
https://www.the12volt.com/installbay/forum_posts.asp?tid=13587&KW=antenna
I'm trying to install a DEI range antenna onto a viper 300+ alarm module. Where am I supposed to hook up the 2 wire connector?
