need help with fiberglass
popeye004
Copper - Posts: 97
Posted: August 03, 2004 at 4:32 PM / IP Logged
Can anyone tell me how I can get my resin moving smoothly so I can applie it with a paint brush. I used resin before but it always seams really heavy and thick hard to run it with a paint brush also kinda sticky. Is there a diffrent type of resin for caraudio and boats cause the one I used was for automotive body work. Any help will be appreciated.
Moderator - Posts: 12,488
Posted: August 03, 2004 at 5:37 PM / IP Logged
If you want it thinner use acetone to thin out the resin.
popeye004
Copper - Posts: 97
Posted: August 04, 2004 at 1:09 PM / IP Logged
how much acetone do I add for how much resin. So I mix the resin and acetone then add the hardner?
tylertime
Member - Posts: 32
Posted: August 04, 2004 at 3:27 PM / IP Logged
just a little bit of acetone...start off small the add more if you need it
and what kind of resin are you using??  i used bondo and everclear  it didn'
t seem too thick
popeye004
Copper - Posts: 97
Posted: August 04, 2004 at 4:50 PM / IP Logged
I think bondo makes the one I use its automotive resin. So all resins are not the same?
defective
Silver - Posts: 642
Posted: August 04, 2004 at 10:07 PM / IP Logged
they are.... just different polyester amounts.... There is actually structure resins, but in custom fabrication situations on small scale, it really doesn't make a difference. If the box was built properly with alot of matting, it's strong as hell.
Always over-estimate on the amout of layers, will save any worry and only costs a little more.
Wednesday, January 7, 2026 • Copyright © 1999-2026 the12volt.com, All Rights Reserved Privacy Policy & Use of Cookies
