fuse amps for fuse holder
fifibone48
Posted: March 10, 2004 at 11:32 AM / IP Logged
Hello, I have an Audiobahn amp that has 3 30 amp fuses in the back of the amp.  The only question I have is what amp fuse should i use for the fuse holder located near the battery.  Do I add the total amps of the ampifire which would be 90 amps so does that mean that I should have an amp fuse up to 90 amps in the fuse holder?
lagatbezan
Copper - Posts: 117
Posted: March 10, 2004 at 4:44 PM / IP Logged
u always want to put a fuse slightly smaller then the ones in the amps.  I would recomend a 70 or an 80.
customsuburb
Gold - Posts: 1,813
Posted: March 10, 2004 at 5:44 PM / IP Logged
Use a 100 amp fuse or a similar sized circuit breaker.
Usmc860222
Member - Posts: 21
Posted: March 10, 2004 at 9:25 PM / IP Logged
you dont use a circuit breaker, if you do that you might fry your sh*t if too many amps are going through it
fifibone48
Posted: March 11, 2004 at 1:16 AM / IP Logged
Yeah, thats what I thought, will use an 80 amps fuse for the fuse holder just to keep my Audiobahn amp out of trouble.  Would hate to fry the Audiobahn amp.  Thanks
