Massive Sub Wiring
Walkercustoms
Copper - Posts: 219
Posted: January 31, 2006 at 12:22 PM / IP Logged
I have a guy that wants 6 Kicker Free Airs installed and be pushed by an old punch45. Yes, I know what is he thinking but, you know how it is his buddy said he had it hooked up that way and so on. Now, he has check this out 4 4ohm and 2 8ohm subs. Is there anyway I could hook these up to the old punch so, I can get him out of my hair?
Walkercustoms
Copper - Posts: 219
Posted: January 31, 2006 at 2:34 PM / IP Logged
It is a Punch 200 DSM 2-Ch not a punch45. The specs are as follows 100x2@4ohm, 200x2@2ohm and 400 per mono block at 4ohm. Any help with hooking up would be great with the sub setup I posted before. It will have to be seris and parr I assume.
DYohn
Platinum - Posts: 10,741
Posted: January 31, 2006 at 3:20 PM / IP Logged
It's a strange configuration and it'll have loudness imbalances, but I'd wire it as two sets of 8-ohm loads in parallel.  Use the 4-ohm woofers in series-parallel and the 8-ohms in parallel as below, and connect each set to one channel of the amp as a 4-ohm load.
Massive Sub Wiring -- posted image.
