dei 528t , clarion max675vdii
shagdrum
Copper - Posts: 68
Posted: February 19, 2008 at 1:11 PM / IP Logged
I have a clarion Max675VDII and am trying to work around the parking brake ground for video issue. Unlike many DVD playing headunits, you can't just ground it, as the unit needs to see a change in the ground signal. I could just install a switch, but I had read about a pulse timer relay someone had used for one of these, on another message board. The post wasn't clear on the wiring or which relay was used. I have a DEI 528T relay to use and need to know how to wire the parking signal up so that when I turn the head unit on, the parking brake ground signal is breifly interupted.
Here is what I was thinking:
BLACK: ground
Red: 12 VDC power
BLACK w/ stripe: not used
YELLOW 30 common: attach to parking brake line from head unit
BROWN 87: not used
ORANGE 87A (normally closed): ground
BLUE wire loop: uncut
Would this be correct?
Big Dog
Gold - Posts: 1,265
Posted: February 19, 2008 at 3:18 PM / IP Logged
Your BLACK/ White is your trigger. Connect it to ignition or something similar which will change polarity and trigger the timer.
I have a VRX575 USB and haven't got around to automating it . . .I have a toggle switch for now.
I'm going to activate it through an aux channel on my Viper which I can link to unlock.
Prepare your future. It wasn't the lack of stones that killed the stone age.
shagdrum
Copper - Posts: 68
Posted: February 19, 2008 at 3:29 PM / IP Logged
I thought if you didn't cut the blue wire loop, that triggered on receiving negative (per the little instruction sheet). I assumed that meant that the relay sensed the unit trying to get ground and you didn't need to use the BLACK/ white.
BTW, great quote by "The Who"
chadwa2003
Copper - Posts: 353
Posted: February 19, 2008 at 10:22 PM / IP Logged
Not that I promote doing this but just take a regular starter kill relay
85 to power antenna wire coming off the clarion
86 and 87a to ground
30 to lt green on the clarion
Now to activate simply turn to unit to tuner then back to dvd and it's just that easy
shagdrum
Copper - Posts: 68
Posted: February 19, 2008 at 10:32 PM / IP Logged
Thanks for the reply...
That makes sense. However I already have the 528T pulse timer relay, might as well use it.
shagdrum
Copper - Posts: 68
Posted: February 20, 2008 at 8:25 AM / IP Logged
...anyone?
Big Dog
Gold - Posts: 1,265
Posted: February 20, 2008 at 9:03 AM / IP Logged
Sorry for not replying, I usually sleep overnight. dei 528t , clarion max675vdii -- posted image.
Yup. Cut the blue so it sees the transition from negative to positive as a trigger.
Big Dog
Gold - Posts: 1,265
Posted: February 20, 2008 at 3:26 PM / IP Logged
Oh, I forgot to add: "For offroad use only!" dei 528t , clarion max675vdii -- posted image.
