1987 mazda rx-7, python 991
19rxseven87
Member - Posts: 26
Posted: June 04, 2010 at 3:37 AM / IP Logged
Hi guys,
I'm new to wiring car security up, but I have done car stereos before.
I have a few questions on the wiring of the python 991 in specific.
I am using the vehicle wiring diagram supplied by the 12volt.
First of all, are many of the wires on the alarm harness not used because of the feature not being needed? For example, on the auxiliary harness H2, the Aux 1 output and Aux 2 output are not used for a regular car alarm install?
The car in question is a 1987 mazda rx-7 with DEI 524 door lock actuators installed.
Secondly I am going to run through the harness and see if I have this correct:
H1/1: trunk release output = not used because i have a manual trunk release
H1/2: constant 12v (+) input = used
H1/3: siren output (+) = used because I need some sound for the alarm
H1/4: light flash - isolation wire- = I'm not sure about this. I have the installation diagram but I don't know what it means by lightswitch and control module in the car? Can anyone elaborate?
H1/5: chassis ground = used
H1/6: (+) door trigger input = used because my door trigger is a positive input
H1/7: trunk pin/instant trigger input = not used??? What does this do?
H1/8: (-) door trigger input = not used because door trigger is positive
H1/9: 200mA dome light output = used if i want the dome light to turn on when i lock and unlock the car??? Can anyone help me??? Uses a relay correct?? Which one and where can I buy it?
H1/10: turbo timer/remote start activation input = used if i need the turbo timer to work, but where and how do i wire this?
H1/11: parking light output = used and connected to parking light
H1/12: 500mA ground when armed output = used but where do i connect this to??
AUXILIARY HARNESS
H2/1: (-) factory alarm disarm output = not used
H2/2: (-) factory alarm output = not used
H2/3: (-) 200mA aux 1 output = not used?? what is this for??
H2/4: (-) 200mA aux 2 output = not used, same as above?
H2/5: (-) 200mA aux 3 output = not used, same as above?
H2/6: (-) 200mA 2nd unlock output = used if i want to be able to push the unlock button twice to unlock all the doors and push once for just the driver door?
H2/7: (-) disel wait to start input = not used?? only for diesel engines??
H2/8: (-) horn honk output = used if i don't want to use the siren?
HEAVY GAUGE 10-PIN CONNECTOR
H3/1: ignition 1 input/output = used
H3/2: (+) fused ignition 2 = used
H3/3: accessory output = used
H3/4: starter output = used (in between the starter input and output right?)
H3/5: starter input = used but going to the ignition switch?
H3/6: (+) (30A) fused ignition relay 1 input = Not sure what to do with this!
H3/7: (+) ignition 2 flex relay output = Not sure what to do with this!
H3/8: 87a of ignition 2 flex relay = Not sure what to do with this!
H3/9: (+) (30A) fused accessory/starter relay input = Not sure what to do with this!
REMOTE START INPUT
1: neutral safety switch input = used for remote start, but is the e-brake wire ok to use?
2: tachometer input wire = used for remote start
3: (+) brake shutdown wire = used for remote start
4: N/0 or N/C (-) hood pin switch input = used, connected to a hoodpin switch?
5: (-200) mA 2nd status/rear defogger = Not necessary to be connected, but will activate rear defroster?
REMOTE START AUXILIARY OUPUT
Harness not necessary unless additional accessories are added that require a remote start to activate it??
DOOR LOCK WIRE DIAGRAMS
Since I am using the DEI 524 N actuators, I will use a "Type D" using a DEI 451M relay.
Sorry for the very long post, but I want to be very thorough for this install. I have always been a little intimidated to install a car security, not because of my soldering abilities, but because I might not be able to locate the right wires.
Thanks a TON in advance.
19rxseven87
Member - Posts: 26
Posted: June 04, 2010 at 3:39 AM / IP Logged
can a mod please change the title to "Help me with a car alarm install?" thanks!
the12volt
Administrator - Posts: 3,957
Posted: June 04, 2010 at 8:20 AM / IP Logged
19rxseven87
Member - Posts: 26
Posted: June 04, 2010 at 2:49 PM / IP Logged
ahh, ok sorry these forum rules are a little more different than standard forums.
19rxseven87
Member - Posts: 26
Posted: June 05, 2010 at 5:35 AM / IP Logged
can anyone please advise?
t&t tech
Platinum - Posts: 2,622
Posted: June 06, 2010 at 7:27 AM / IP Logged
on the h1 harness, eliminate the parking light isolation wire you don't need it!
Are you sure that car is positive trigger?
For the dome light you need a single pole single throw relay or single pole double throw, doesn't matter any will do fine!
No need for the Ground when armed wire, the unit has built in immobiliser, (unless you're using it to wind up windows or something)
The turbo timer input eliminate this as well
All the heavy gauge reds go to 12 volts constant
The pink/black flex relay input, eliminate this!
tedmond
Gold - Posts: 4,610
Posted: June 06, 2010 at 9:30 AM / IP Logged
make sure you test your wires !
Ted
Compustar Expert
19rxseven87
Member - Posts: 26
Posted: June 09, 2010 at 5:48 AM / IP Logged
The car has a negative door trigger.
So, is the dome light supervision wire necessary or not?
I want to have the turbo timer functional on this unit so I need to keep the tuber timer input wire. But I don't know what to do with it. Can any of you help? Also I found on this page the ground when armed output on the factory harness but I don't know if I should wire it or not, should I? Or should I leave it cut?
So, on the H1 harness, can I cut the trunk release output, the light flash isolation wire, the positive door trigger input, trunk pin/instant trigger input?
How would I go about testing the wiores for something like ignition 1 / 2 starter output?
Thanks in advance.
Posted: June 09, 2010 at 4:12 PM / IP Logged
The trunk pin wire (blue, H1/7) connect this to trunk light trigger, microswitch) in hatch lid catch otherwise, if someone forced the trunk lid, you've no protection. On that model you have to wire back to the trunk lid catch. Cut the others.
Don't need light isolation wire.
Dome light BLACK/ white to relay 85, constant 12V+ 5amp fused to 86, ground to 87 and 30 to to green door trigger wire.
H1/10 WHITE/ blue turbo timer wire to relay 85, 30amp fused constant to 86 and 87, 30 to your ignition input/output wire. Programme that wire for approx 1 1/2 mins.
H1/12 only required with window closers.
Ignore H2/3 6 and 7.
H/3, 4 & 5 YES
H3/6 to battery.
H3/7 and 8 Do you have a second ignition wire? H3/9 to battery.
1) Yes
2)Use tach line on inst. panel for this.
3 to side of brake switch that goes 12v+ when brake pedal is depressed.
4 Yes as n/o when hood is closed (goes to ground when hood is opened,
absolutely mandatory with a remote start.
5 Probably need to feed an outboard relay which is connected to the hot window power side.
Rem start aux output..correct.
Locks. are you using a dedicated relay with them? If not use the 451.
19rxseven87
Member - Posts: 26
Posted: June 09, 2010 at 5:22 PM / IP Logged
What do you mean by the hatch lid catch?
Are you saying I need additional relays (purchased elsewhere like radio shack) for the dome light, and turbo timer??
What do you mean by a second ignition wire?
Also for the 451m, what do you connect the purple fused wire to? Do you connect it to a constant 12v or do you connect it to a switched 12 v?? I have the green and the blue wires on both actuators connected in parallel connected to the 451m and I have the other wires connected to the ground, but I haven't connected the purple wire yet because I am unsure if it needs to go to a constant 12v or a switched 12v.
Page of 5
Wednesday, January 21, 2026 • Copyright © 1999-2026 the12volt.com, All Rights Reserved Privacy Policy & Use of Cookies
