Rendezvous R/S acc. wire
pauls328
Member - Posts: 6
Posted: January 28, 2006 at 10:50 AM / IP Logged
I'm installing a remote start in my wife's '02 Rendezvous and I'm not sure which accessory wire to power. The wiring info says an orange wire, but there are 4 of them. The factory manual lists 3 as battery voltage and 1 as ignition 3 voltage. Only the brown wire is listed as accessory voltage. Does anyone know which orange wire ( I assume the one listed as ignition 3, but I thought it would be a good idea to check first.) to use and does the brown wire need to be powered as well?
Thanks,
Paul
Paul S
kohara73
Copper - Posts: 192
Posted: January 28, 2006 at 10:59 AM / IP Logged
pauls328
Member - Posts: 6
Posted: January 28, 2006 at 12:09 PM / IP Logged
Thanks for the info. It seems the Orange ign wire powers a relay to fire up power to the heater so that looks like a good bet.
Paul
Paul S
sparkie
Platinum - Posts: 2,061
Posted: January 28, 2006 at 2:10 PM / IP Logged
Make sure that you use the light blue wire in the light blue plug of the BCM for parking lights. It is the negative switched wire fromt he headlight switch. If you use the positive parking light wire, it will turn on the check engine light.
sparky
pauls328
Member - Posts: 6
Posted: January 28, 2006 at 2:26 PM / IP Logged
Thanks, I've got that marked as position A6 on the small grey connector at the BCM. Sound right?
Paul
Paul S
mike swanson
Copper - Posts: 290
Posted: January 28, 2006 at 2:34 PM / IP Logged
Also DONT USE THE ORANGE FOR 12volts
Look in the center console for 2 big red power wires!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!
mike swanson
Copper - Posts: 290
Posted: January 28, 2006 at 2:39 PM / IP Logged
Here*****
Wire/Function Vehicle Colour Location/Description Polarity
PASSIVE ANTI-THEFT YES TRANSPONDER SEE NOTES
12 VOLTS Orange (small gauge)* USE RED POWER IN CENTER CONSOLE Ignition switch harness +
IGNITION Pink Ignition switch harness +
IGNITION 2 Dk.green Ignition switch harness +
ACCESSORY Orange Ignition switch harness +
STARTER Yellow Ignition switch harness +
TACH SIGNAL White At coil on top left of engine AC
FUEL INJECTOR Opposite from Pink At any injector on engine AC
LOCK RED / black Pin-B4 on C2 connector at BCM** -
UNLOCK RED / black Pin-B4 on C2 connector at BCM** -
DOORPIN SEE NOTES***
TRUNK PIN RED / black Pin-A8 on C2 connector at BCM**** -
TRUNK RELEASE WHITE/ black Pin-B1 on C0 connector at BCM**** -
FACTORY ARM SEE NOTES*****
FACTORY DISARM Violet Pin-A4 on C2 connector at BCM***** -
BRAKESWITCH White At switch above brake pedal +
PARKLIGHTS Brown Pin-B3 on C1 connector at BCM**** +
HAND BRAKE ORANGE / black Pin-A2 on C2 connector at BCM**** -
HORN Black At steering column -
DRIVER WINDOW UP Brown At switch in driver's door REV POL
DRIVER WINDOW DOWN Dk.blue At switch in driver's door REV POL
PASSENGER WINDOW UP Lt.blue In driver's kickpanel REV POL
PASSENGER WINDOW DOWN Tan In driver's kickpanel REV POL
LEFT REAR WINDOW UP Dk.green In driver's kickpanel REV POL
LEFT REAR WINDOW DOWN Purple In driver's kickpanel REV POL
RIGHT REAR WINDOW UP Lt.green In driver's kickpanel REV POL
RIGHT REAR WINDOW DOWN Purple In driver's kickpanel REV POL
HEADLIGHTS Yellow At light switch harness -
REVERSE LIGHTS Lt.green At fuseblock in center console -
DIMMER Gray At any illuminated switch in dash -
VSS WIRE Dk.green Pin-B8 on C0 connector at BCM**** 4000ppm
KEY SENSE Lt.green Pin-A1 on C0 connector at BCM**** -
DATABUS INTERFACE Pin-2(top row from left) Diagnostic plug below dash DATA
Vehicle notes
PLEASE NOTE: This vehicle is equipped with TRANSPONDER chips in the ignition keys. This system must be bypassed for Remote Starter installation. A keyless bypass module may be available, contact your distributor to find out. If one of these modules is not available to you, see the appropriate security diagram for bypass instructions.
* This wire should not be used to power a remote starter. You can run a line to the battery, or you can find power at the relays in the center console by removing the plastic side panel on the driver's side of the console. See the exploded view.
** This is a 1-wire doorlock system. A 470-ohm resistor to lock and a direct ground to unlock. This wire is located at the BCM in the center console. See the DOORLOCK diagram for exact wiring instructions.
*** Driver's door is DK.BLUE (pin-A7 on Pink plug), DK.BLUE/WHITE (pin-A3 on Pink plug) for other 3 doors. See the BCM diagram for exact pin locations.
**** The Body Control Module is locate behind the center console. Remove the plastic panel on the driver's side of the console to access. See the BCM diagram for exact pin locations.
***** System can be armed by pulsing the doorpin at the same time as lock. If your car starter has an arm wire, it can be connected directly to the doorpin. If you have to use the lock wire, be sure to use diodes to isolate the doorpin and lock relay or the doors will lock every time the door is opened. See the doorlock diagrams for exact wiring details.
sparkie
Posted: January 28, 2006 at 3:58 PM / IP Logged
Yes the light blue wire is in A6 of the smallest plug in the BCM.
sparky
pauls328
Member - Posts: 6
Posted: January 28, 2006 at 6:21 PM / IP Logged
Looks like I've got the R/S ignition wiring and the bypass module installed. (Car still runs and I haven't set the air bags off (yet!). I got the tach signal at the PCM connector C1 pin 8. It was less of a struggle to get to compared with the coil. All that's left now is the control and power to the relay satellite. Thanks to everyone for the help.
Paul
Paul S
