528t for extra sirens
mrcllusb
Copper - Posts: 489
Posted: May 15, 2006 at 6:42 AM / IP Logged
How do i wire in a 528t so that when i arm my alarm the interior sirens don't chirp and only go off when the alarm gets set off?
Black w/stripe-trigger input (which trigger?)
Black-ground
Red-12v
Orange 87a-?
Brown 87-?
Yellow 3o-?
Where does the red wire from sirens go?
"ole blake"
dxdenis02
Copper - Posts: 72
Posted: May 15, 2006 at 2:30 PM / IP Logged
if your alarm has a horn output you can use that  it turns on only when full trigger......
mrcllusb
Copper - Posts: 489
Posted: May 15, 2006 at 6:09 PM / IP Logged
My system does not have a horn output.
"ole blake"
mrcllusb
Copper - Posts: 489
Posted: May 17, 2006 at 9:07 AM / IP Logged
Anyone?
"ole blake"
Twelvoltz
Platinum - Posts: 2,384
Posted: May 17, 2006 at 10:08 AM / IP Logged
You make no mention of what system you have, but if it provides an armed output use that to trigger the 528t. Cut the wire supplying the siren and connect as follows.
528T               Connection
Red                 Constant fused 12V+
Black               Ground
Orange 87a          One leg of interior siren supply
Yellow              Other leg of interior siren supply
Black w/stripe      Ground when armed output from alarm
Set your timer for however long you want the interior siren to be disabled for. This will disconnect the siren supply each time the ground when armed output of the alarm is activated.
Hope this helps.
mrcllusb
Copper - Posts: 489
Posted: May 17, 2006 at 5:19 PM / IP Logged
Oh i'm sorry.I have a clifford arrow 3.It has a (-) armed output
"ole blake"
mrcllusb
Copper - Posts: 489
Posted: May 18, 2006 at 3:53 AM / IP Logged
So orange 87a will be the piezo siren (+) wire and yellow will go to the piezo siren (-) wire?
"ole blake"
mrcllusb
Copper - Posts: 489
Posted: May 18, 2006 at 5:51 PM / IP Logged
anyone?
"ole blake"
