Normaly closed relay
mikes702
Posted: May 08, 2006 at 2:40 AM / IP Logged
I have installed a Sho-me LED flasher unit to my custom LED taillights on my 2005 Dodge Magnum Rt. my problem is that all 3 of my taillights are wired together so they all flash together instead of left and right wig wag. I bought a 5 pin relay and harness. And I have found the wire that links the taillights together. Now I just need some professional help on how to hook up the relay. Basically I just need it to break the contact between the taillights when powered on, then when off I need it to make contact again for my break lights to function.
hotwaterwizard
Silver - Posts: 1,350
Posted: May 09, 2006 at 8:57 PM / IP Logged
Normaly closed relay -- posted image.
86 is power
85 is ground
30 is input
87a is normally closed until power is applied to 86 and
87 is normally open until power is applied to 86.
John DeRosa (Hotwaterwizard)
Stockton California
When in doubt, try it out !
Thursday, November 6, 2025 • Copyright © 1999-2025 the12volt.com, All Rights Reserved Privacy Policy & Use of Cookies
