03' honda accord
mxxmikexx
Silver - Posts: 796
Posted: December 22, 2002 at 11:53 AM / IP Logged
does anyone have a wiring diagram for an 03' honda accord (2 door) , i have one for an 02' but im not sure if the info is the same on the 03' or not.
mxxmikexx
Silver - Posts: 796
Posted: December 22, 2002 at 3:43 PM / IP Logged
well the 03' is definatly different from the 02' . ive managed to find everything except the lock/unlock wires. i found one wire at the power door lock switch that will lock the doors with a neg. pulse, but no other wire will test to unlock the doors. i checked on transponderbypass.com and they list an interface kit for mulitplex door locks and alarm for the 03'. so it looks like we have another car that requires additional modules to make these damn things work.
JWorm
Platinum - Posts: 2,208
Posted: December 22, 2002 at 4:26 PM / IP Logged
HONDA / ACCORD / 2003 / Remote Start
12volts      white       +       ignition harness
Starter      BLACK/ white       +       ignition harness
Second Starter      N/A
Ignition      BLACK / YELLOW       +       ignition harness
Second Ignition      N/A
Third Ignition      N/A
Accessory      BLACK/ red       +       ignition harness
Second Accessory      WHITE/ red       +       ignition harness
Keysense      RED / white or RED / black       -       ignition harness
Power Lock      pink/black       -       grn plug, L side of fusebox
Notes: These wires will meter while using the passenger door lock switch.
Power Unlock      pink/blue       -       grn plug, L side of fusebox
Lock Motor      yellow/black       5wi      grn plug, front of fusebox
Unlock Motor      YELLOW /GREEN       5wi      grn plug, front of fusebox
Parking Lights+      RED / black       +       large wht plug above fusebox
Parking Lights-      BLACK/ red or blue/red       -       in steering column cover
Hazards      GREEN/ red       +       large wht plug above fusebox
Turn Signal(L)      RED / blue       +       large wht plug above fusebox
Turn Signal(R)      brown       +       large wht plug above fusebox
Reverse Light      green       +       driver kick, harness to rear
Door Trigger      GREEN/ red       -       grn 5 pin plug behind fusebox
Dome Supervision      use door trigger
Trunk/Hatch Pin      blue/black       -       driver kick, harness to rear
Hood Pin      yellow/red       -       hood pin switch in latch
Trunk/Hatch Release      YELLOW /GREEN       +       driver kick, harness to rear
Power Sliding Door      N/A
Factory Alarm Arm      WHITE/ red       -       driver door module in door
Factory Alarm Disarm      white       -       driver door module in door
Disarm No Unlock      see factory alarm disarm
Tachometer      blue/red or blue       ac       ECM/PCM
Notes: The ECM/PCM is on the front of the transmission tunnel. The connectors are on the passenger side. On the 4 cylinder models the tach wire is in the white 31 pin connector E, pin 25. On the 6 cylinder models it is in the gray connector A, pin 23.
Wait to start      N/A
Brake Wire      WHITE/ black       +       brake pedal switch
Parking Brake      GREEN/ orange       -       large wht plug above fusebox
Horn Trigger      GREEN/ YELLOW       -       steering column
Memory Seat 1      N/A
Memory Seat 2      N/A
Memory Seat 3      N/A
Immobilizer By Pass : Not Availab
