2003 nissan xterra starter grind
advanced
Copper - Posts: 207
Posted: October 19, 2007 at 5:57 PM / IP Logged
I installed an Audiovox APS-57 in a 2003 Nissan Xterra & everything works fine, except when I remotely start it & then I get in & put the key in the ignition & turn it to go, I get a starter grind noise as I'm turning the ignition to "on" position.
There's no transponder in key.
I can't figure it out. Any Ideas??
Good Enough Isn't!
Twelvoltz
Platinum - Posts: 2,384
Posted: October 19, 2007 at 6:34 PM / IP Logged
How did you wire up the second starter output?
advanced
Copper - Posts: 207
Posted: October 19, 2007 at 7:03 PM / IP Logged
First I tied the 2 starter wires together to the remote start "starter" wire. In an effort to find the problem, I then isolated the 2nd starter wire with a relay. The same thing happens.
Good Enough Isn't!
NowYaKnow
Gold - Posts: 1,217
Posted: October 19, 2007 at 7:12 PM / IP Logged
From another post
#85 to the negative out when running wire from the remote starter; #86 to ignition; #87 to the starter wire from the remote start; Cut the vehicles starter wire - #87a to the key side of cut starter wire; #30 to the starter motor side of the cut starter wire
