2008 Lexus Rx350 Alarm/Remote Start/Stereo Wiring
jaybizz
Member - Posts: 30
Posted: February 04, 2008 at 10:18 PM / IP Logged
anyone have the wiring diagram for alarm/remote start for this car. is it the same as the 07?
alarm king
Twelvoltz
Platinum - Posts: 2,384
Posted: February 05, 2008 at 7:35 AM / IP Logged
Audiovox lists:
          #513334: 2008 LEXUS RX350 4DR SUV WITH 3.0L ENGINE AND STANDARD AUDIO SYSTEM
     Audio/Mobile Video
     WIRE          COLOR          POLARITY          LOCATION
     Battery          LIGHT BLUE          (+)          RADIO HARNESS
     Accesory          GRAY          (+)          RADIO HARNESS
     Ground          BROWN          (-)          RADIO HARNESS
     Illumination          GREEN          (+)          RADIO HARNESS
     Power Antenna          ORANGE          (+)          RADIO HARNESS
     LF Speaker (+)          BROWN
     LF Speaker (-)          RED / YELLOW
     RF Speaker (+)          VIOLET
     RF Speaker (-)          WHITE
     LR Speaker (+)          RED
     LR Speaker (-)          GRAY
     RR Speaker (+)          BLUE/BLACK
     RR Speaker (-)          PINK
     Amp Location          UNDER PASSENGER REAR SEAT
     Radio Security          YES
     Security
     Battery          RED          (+)          IGNITION SWITCH HARNESS
     Ignition 1          PURPLE          (+)          IGNITION SWITCH HARNESS
     Starter 1          BLUE          (+)          IGNITION SWITCH HARNESS
     All Door Trigger          USE LATCH WIRES
               MUST DIODE ISOLATE ALL WIRES
     Domelight Super          LIGHT BLUE          (-)          RIGHT SIDE OF FUSE BOX
     LF Latch          BLUE          (-)          ECM/DRIVERS SIDE FUSEBOX
     RF Latch          BLUE          (-)          ECM/DRIVERS SIDE FUSEBOX
     LR Latch          BLACK          (-)          ECM/DRIVERS SIDE FUSEBOX
     RR Latch          GREY          (-)          ECM/DRIVERS SIDE FUSEBOX
     Trunk Trigger          PINK          (-)          DRIVERS KICK
     Hood Trigger          BLACK          (-)          AT HOOD LATCH UNDER HOOD
     Alarm Disarm          DISARMS WITH UNLLOCK
     Alarm Arm          ARMS WITH LOCK
     Parking Lights          BLUE          (+)          DRIVERS SIDE FUSEBOX
     Convenience
     Headlights-Lo          VIOLET          (-)          AT SWITCH
     All Hazrd Lights          VIOLET          (-)          AT SWITCH
     Wipers-Lo          LIGHT BLUE          (+)          AT SWITCH
     Wipers-Hi          GRAY          (+)          AT SWITCH
     Parking Brake          LIGHT GREEN          (-)          AT SWITCH
     Trnk Release          PURPLE          (-)          HATCH RELEASE SWITCH
     Fuel Dr Release          GRAY          (+)          AT SWITCH ON DASH
     Seat Mem 1          GREEN          (-)          AT SWITCH IN DOOR
     Seat Mem 2          VIOLET          (-)          AT SWITCH IN DOOR
     Remote Start
     Ignition 2          GREEN          (+)          IGNITION SWITCH HARNESS
     Accessory 1          RED          (+)          IGNITION SWITCH HARNESS
     Starter 2          WHITE          (+)          IGNITION SWITCH HARNESS
     Anti-Theft Type          TRANSPONDER
     Key Sense          BLACK          (-)          STEERING COLUMN HARNESS
     Tachometer          ANY UNCOMMON WIRE COLOR          (AC)          ANY FUEL INJECTOR OR COIL PACK
     Speed Sense          LIGHT GREEN          (AC)          AT ECM BEHIND THE GLOVEBOX
     Brake Lights          BLUE          (+)          BRAKE SWITCH
     Reverse Lights          RED          (+)          DRIVER KICK
     Horn          WHITE          (-)          STEERING COLUMN HARNESS
     Modules
     WIRE          LOCATION
     Module 1          ECM IS BEHIND GLOVE BOX
     Doorlocks/Windows
     Power Unlock          GRAY          (-)          DRIVERS DOOR AT KEY CYLINDER
               DOUBLE PULSE
     PowerLock          BROWN          (-)          DRIVERS DOOR AT KEY CYLINDER
     Driver Mtr Unlock          WHITE          (REV)          DRIVER KICK
     Driver Mtr Lock          RED          (REV)          DRIVER KICK
     Pas Mtr Unlock          RED          (REV)          TOP RIGHT OF FUSE BOX
     Note: Audiovox makes no representation or warranty with respect to the above information including its accuracy, completeness, or its freedom from third parties' proprietary rights. Audiovox disclaims all liability or responsibility for errors or omissions therein or any decision made by the recipient in reliance thereon. The installer must verify any circuitry with the proper test equipment prior to installation.
jaybizz
Member - Posts: 30
Posted: February 22, 2008 at 10:48 PM / IP Logged
if possible do you have a DEI wiring diagram because i've noticed the audiovox print out tells you to go places that you really don't have to go for the wires. like the other day i was doing a 2004 honda accord and the audiovox print out was telling me to go to the driver door switch in the door for the doorlocks. in fact the wires are in the kick panel, so i ended up doing the car with no print out at all and didn't have a problem. if anybody does have a DEI print out i would really appreciate it. thanks
alarm king
