2007 suburban, alarm wiring
arlanandglenda
Posted: March 11, 2007 at 12:12 AM / IP Logged
I am installing a car alarm for a 2007 Suburban. I looked in the wiring database and there wasn't one for a 2007 Suburan. Can anyone help by providing wiring schematics? Thanks.
KarTuneMan
Platinum - Posts: 7,056
Posted: March 11, 2007 at 12:27 PM / IP Logged
PASSIVE ANTI-THEFT YES TRANSPONDER   SEE NOTES
 This vehicle is equipped with a TRANSPONDER passive anti-theft system. A bypass module may be available which will not require a key. Contact your supplier to find out. If one is not available to you, please see the appropriate security diagram before any remote start installation.
 12 VOLTS RED / black In black plug on fusebox under dash   +
 IGNITION Pink Ignition switch harness   +
 ACCESSORY Brown Ignition switch harness   +
 STARTER White Ignition switch harness   +
 Start wire requires (+) through a 1280 ohm resistor.
 KEY SENSE Pink Ignition switch harness   +
 TACH SIGNAL SEE NOTE
 Go to any coil on the side of the engine and use the wire that is not Pink, Black or Brown.
 FUEL INJECTOR Opposite from Pink At any injector on engine   AC
 LOCK Data module required
 UNLOCK Data module required
 DOORPIN Gray At BCM on the left side of the steering column   +
 Located in the TAN connector.
 TRUNK PIN Pink/black At BCM on the left side of the steering column   -
 Located in the PINK connector.
 TRUNK RELEASE Gray At BCM on the left side of the steering column   -
 Located in the PINK connector. The glass release wire is PINK and is found in the same connector.
 FACTORY ARM Data module required
 FACTORY DISARM Data module required
 The OEM alarm will disarm automatically on remote start.
 BRAKESWITCH Blue/white At switch or BCM on left of steering column   +
 Located in the BROWN connector.
 PARKLIGHTS (-) Lt.blue At light switch or BCM on left of steering column   -
 HAND BRAKE Lt.blue At BCM on left of steering column   -
 HORN Tan At steering column or BCM   -
 Located in the BROWN connector. The BCM is located on the left side of the steering column.
 VSS WIRE Yellow/black In Black connector on ECM   AC
 The ECM is located on the driver's side of the engine compartment behind the headlight.
Tuesday, April 14, 2026 • Copyright © 1999-2026 the12volt.com, All Rights Reserved Privacy Policy & Use of Cookies
