BMW Remote Start
mjmauto
Member - Posts: 43
Posted: October 23, 2005 at 7:55 PM / IP Logged
I installed a  Hornet 546t remote start in a 2002 BMW 325i  and everything works fine , except that there is a problem with the car starting. It will start if I hold a key right next to the cylinder so I am sure it is an issue with the bypass module.  I have tried the dei and one other bypass module but they both do the same thing.   Is there a vehicle specific module or is there some other way to wire it up so that it will remote start ? Any help is appreciated.
cntrylvr79
Silver - Posts: 582
Posted: October 23, 2005 at 10:23 PM / IP Logged
If you look at the wiring diagram for the 556u the one it says will not work on bmw actually does work with bmw.  I ran into the same problem on the same exact car, and that's how I got around it.  The car starts normally now.
Cause I'm So white and nerdy...
First Class Certi-fried installer
Montrealler
Copper - Posts: 155
Posted: October 23, 2005 at 10:29 PM / IP Logged
You need to open one wire from the factory loop circuit next to the barell , the black antenna of the receiver.
Then attach on each side one lead from the loop circuit. Discard the supplied loop.
KarTuneMan
Platinum - Posts: 7,056
Posted: October 23, 2005 at 10:43 PM / IP Logged
If that fails....get a factory transponder ring. BMW part# 66-008362278 should be bout $35.00 no fault, works everytime when wired correctly. The BMW transponder system is very touchy, the number of coils around the key is more important on the BeeM'rs than other cars.
Montrealler
Copper - Posts: 155
mjmauto
Member - Posts: 43
Posted: October 24, 2005 at 10:47 AM / IP Logged
Thanks for all the help.  I will try these sugestions and let you know what happens.  Thanks.
5150azn
Silver - Posts: 584
Posted: October 24, 2005 at 10:59 AM / IP Logged
Yeah man. I recommend just getting the factory ring. I've done newer BMW's and haven't had any luck other than using the factory ring. It should save you some time anyways.
Tell the Snap-On guy I'm not here!
