2003 mercedes benz e320 tech sheet
Earmarkcaraudio
Posted: August 31, 2004 at 1:50 PM / IP Logged
anyone know where i can find a  wiring code sheet for a 2003 mercedes benz e320??
mo12v
Posted: August 31, 2004 at 3:19 PM / IP Logged
Constant 12 voltsREDIGNITION SWITCH HARNESS
Ignition 12 voltsGRAY OR TANIGNITION SWITCH HARNESS
StarterWHITEIGNITION SWITCH HARNESS
Dome LightYELLOW (-)DRIVERS KICK PANEL OR TAN (-) *
Trunk Pin SwitchWHITE (-)AT KEYLESS *
Parking LampBLUE (R) LT.GREEN (L)(+) HEAD LIGHT SWITCH.
Power LockWHITEUNDER CENTER CONSOLE OR
Power UnlockGREEN & PINKAT KEYLESS * **
* At Keyless Module Located Under Hood Behind Fuse Box. ** The green will unlock only the drivers door , the pink will unlock all of the other doors. Negative Pulse Door Lock Digram
Accessories
Window UpD\WHITE P\ WHITE D\ WHITE P\ GREEN
Window DownF/TAN F/ TAN R/ GRAY R/ BLUE
Ign Key Warn
Trunk ReleaseGRAYAT KEYLESS * (CHECK POLARITY)
OEM HornORANGE (-)STEERING COLUMN
Headlights
OEM Alarm ArmFACTORY REMOTECONTROLED
OEM Alarm DisarmONLY
Remote Start
Tach SignalVIOLET/WHITEAT IGNITION COIL
Ignition #2TANIGNITION SWITCH HARNESS
Ignition #3
Accessory
Neutral Safety
Brake LightBLACK/ RED (+)AT SWITCH ABOVE PEDAL
Reverse Light
Rear Window Defrost
Immobilizer Bypass  *CAUTION*
* This Vehicle Has An Immobilizer That Needs To Be Bypassed When Adding A Remote Start.  CAUTION: There Have Been Some Complaints That After A Period of Time After Installing The Remote Start, The Transponder In The Keys Would Get Deleted And The Vehicle would Have To Go Back To The Dealer For Reprogramming.
MO
Sunday, May 10, 2026 • Copyright © 1999-2026 the12volt.com, All Rights Reserved Privacy Policy & Use of Cookies
