01 grand am remote starter and bypasskit
hip-hoppy45
Posted: September 19, 2008 at 3:14 AM / IP Logged
Hi all from the new guy
I'm trying to install a prostart remote starter in my 01 Grand Am I'm also using a gmbp bypasskit ,problem is when I start it with remote it just turns over constantly till I press the button again, or it will start and run for about 1-3 seconds and shut off.  All programing seems to be fine as I get all the proper flashes in the sequences that they should.  With  a key in the ignition turned to acc/on the remote start works fine. But I think thats kinda dumb.  I've run out of ideas here and don't know what to try next. I'd appreciate any suggestions from one of you smarter people as to what I may not be doing or have done wrong.  The long cold northern Canadian winter will be here soon and the wife and I would really like to have this working as we both suffer with arthritis.  A nice big color coded diagram of  the car, remote starter and bypasskit wiring with all the a b c's at this point is probably about the most I could comprehend.
 Anyway thankyou all that may be able to help us before the big freeze01 grand am remote starter and bypasskit -- posted image.
kgerry
Platinum - Posts: 3,455
Posted: September 19, 2008 at 4:30 PM / IP Logged
did the GMBP program correctly?  did you move the jumper from program mode to operation mode as per the install guide?
Kevin Gerry
MECP First Class Installer
Owner/Installer
Classic Car Audio
since 1979
sterling_silver
Member - Posts: 7
Posted: September 19, 2008 at 7:42 PM / IP Logged
hi!
just my experienced and wanna share it. I also have installed a remote start DEI to my vehicle Galant 04. After finishing i've tried to start the car using the remote, it did but also shut off after 1-3 seconds. What i did was I changed the programming of my alarm brain using the valet LED button. I changed the default ENGINE CHECKING TACH to ENGINE CHECKING VOLTAGE since i ddn't connect my tach wire and hard to reach the ignition coil in the engine compartment. Afte that i've tried to remote start again the vehicle, but shut off again after 1-3 seconds. I tried to start the vehicle first using my key for a few minutes and then shut it off guessing that it might be the cranked time wasn't enough (Default setting is 0.6 seconds). THen, i tried to remote start the vehicle and it did, so the next thing that i did was adjust the crank time to 1.2 seconds, finally it start using the remote start.
Hope this helps anyone!
Thank you!
Sterling_Silver
1 Work Done = Eat
2 Work Done = 1 Sleep
Never Eat, Never Sleep
chriswallace187
Gold - Posts: 1,661
Posted: September 19, 2008 at 11:49 PM / IP Logged
Most likely the problem is either your bypass isn't programmed/wired correctly, or you're missing a required ignition wire. On that car you should be connecting 2 ignition and 2 accessory wires, and you shouldn't power an accessory as an ignition or vice versa.
The pink and the green wires need to stay hot during crank, the brown and orange ones need to drop voltage during crank.
C Renner's Auto Electronix
hip-hoppy45
Posted: September 20, 2008 at 2:07 AM / IP Logged
Thanks Chris at least something to check out, my mechanic buddy and I have been at this for several hours on several weekends.
Thank you again!
Hoppy
hip-hoppy45
Posted: September 20, 2008 at 2:18 AM / IP Logged
Kevin yes I believe we did all this, but something to double check in any case.
ccajay
Member - Posts: 11
Posted: September 21, 2008 at 8:19 PM / IP Logged
I usually dont use the brown second accessory wire but you MUST have both ignition wires connected and like the other guy said your acc wire needs to see 12 volts before and after crank but not during
Thank you
Jayson Cook
Columbus Car Audio & Accessories
saskpuller
Copper - Posts: 144
Posted: September 22, 2008 at 12:16 AM / IP Logged
The second ignition wire on that car is green and I have only found it at the ignition barrel. Kind of a pain to get at. I usually take the radio out and grab the wires from there. If you have all those wires hooked up right, I would assume the GMBP is not being programmed correctly. IIRC put the jumper horizontal on the bottom and start the car. Shut car off and move jumper back vertical on left. That is totally from memory so I could be wrong. You can get a install guide for the kit at www.bypasskit.com . If still having issues, tell us what wires you have hooked to what. Can the starter do a takeover? Start the car with the key and then push the r/s button. Shut off car. If car still runs, you have a bypass issue. If not, probably a tach thing.
