Posted: November 20, 2005 at 5:41 PM / IP Logged
Posted: November 20, 2005 at 9:03 PM / IP Logged
Posted: November 20, 2005 at 9:35 PM / IP Logged
Posted: November 20, 2005 at 10:46 PM / IP Logged
Posted: November 20, 2005 at 10:57 PM / IP Logged
Posted: November 20, 2005 at 11:02 PM / IP Logged
Posted: November 20, 2005 at 11:11 PM / IP Logged
Posted: November 21, 2005 at 3:37 AM / IP Logged
Posted: November 22, 2005 at 4:05 PM / IP Logged
Posted: November 22, 2005 at 5:41 PM / IP Logged
Saturday, April 25, 2026 • Copyright © 1999-2026 the12volt.com, All Rights Reserved • Privacy Policy & Use of Cookies
Neat feature with the mode switch from resistance mode, sounds handy.
I've seen probe clips that can make measurements through insulation by piercing it with a needle tip while holding the wire centered; that'd probably be handy to confirm the right wire with minimal effort.
Stainless steel probe pierces insulation on 14, 16 and 18 gauge wire. You control needle depth to minimize insulation damage. Essential for use under hood or under dash. Use it on fuel injectors or sensors while providing complete insulation to grounding due to design. * Banana jack accepts all DMM and banana jack leads * Non-rotating banana jack prevents leads from tangling, allowing you to tighten/loosen clamp while still connected to the test lead * For use with test leads with 2 mm probes * Tested to 60 V DC
