relay buss or relay distribution block
magyver
Posted: February 21, 2007 at 7:18 PM / IP Logged
im in the process of doing a project where i need 32 12V relays. yes, its a crazy lighting/audio system that i am working on for a spa using DMX controls to control lights, water jets, fans, ect ect. and i need 32 12V relays. SO, i need somthign that i can just put in 12V, ground, as a common, then have my signals and outputs in one unit. or multiple. as 32 hand wired regular old 12V relays is gonna look and be very redundant.  ive been scowering the www but cant find crap it woulb be nice to at least find one w/ ya know, 6 or 8 or 10 or some ish just to keep it clean.  anyone got anything? needs to be able to activate at 150ma..
thx in advance
hotwaterwizard
Silver - Posts: 1,350
Posted: March 01, 2007 at 10:50 PM / IP Logged
If you can use 8 pin relays I have alot of these sockets you can use for this project.
You can make a chassis then you drill a hole for each one and mount as manny as you need. All of the wires are hidden below the chassis and all you see are rows of relays. You can even polish Aluminum so the chassis looks like a mirror with a bunch of relays pluged in to it.
relay buss or relay distribution block -- posted image.
John DeRosa (Hotwaterwizard)
Stockton California
When in doubt, try it out !
hotwaterwizard
Posted: March 05, 2007 at 11:03 PM / IP Logged
Look what I found!
Website
http://www.customconnector.com/product_line.htm
Datasheet
http://www.customconnector.com/PDFs/Page29.pdf
Picture Link
http://www.customconnector.com/AUTOMOTIVE_RELAY.JPG
Stockton California
