Posted: July 27, 2006 at 8:14 PM / IP Logged
Posted: July 28, 2006 at 11:39 PM / IP Logged
Posted: July 29, 2006 at 11:40 AM / IP Logged
Posted: July 29, 2006 at 11:48 AM / IP Logged
Posted: July 29, 2006 at 1:45 PM / IP Logged
Friday, April 3, 2026 • Copyright © 1999-2026 the12volt.com, All Rights Reserved • Privacy Policy & Use of Cookies
I have asked the local electronics supply house for a mechanical latching relay that would work in this schematic that I brought to them but have been unable to come away with a working relay.
I have built this with a magnetic latching relay, but it needs to reverse the coil poles in order to work properly I believe.
It there a mechanical latching relay that exists that will change the input coil charge and return the contacts from initial position (locked) [momentary push] to 2ndary position (locked) [momentary push] and back to initial position? Using one momentary push button, and require no power to maintain its position while in the off position?
If this helps describe the operation I seek, as it seems to have confused a few people I have talked to.
Thank you for any help completing this seemingly simple task!
