you guys work on '04 Camrys
the_doctor
Posted: September 04, 2004 at 3:53 AM / IP Logged
the year 04 brings many changes to toyota, i used to enjoy installing security and and such on toyotas. now i must get these cars down, when doing alarm/remote start. anyone that can help a brother out...
Street Scenes
Mpls. MN
Platinum - Posts: 12,488
Posted: September 04, 2004 at 12:00 PM / IP Logged
What do you need help with on these vehicles ?
the_doctor
Posted: September 04, 2004 at 10:01 PM / IP Logged
well consistant  wiring info would be great. i look all over and come up with bullsh*t everywhere. i have been installing for approx. 6 years. however with the '04 camry it kicks my ass every time. between the child safety locks (which i think i got now) and the second start wire, that headlight B.S. which i have yet to mess with, five wire trunk, multiple door triggers, you name it. yes i know the key sense wire can be used as the one and only door trigger but if the factory keyless is used to unlock the alarm goes off. Please Help to set the record straight. i dont know who we pissed off at toyota but we must have done a fine job.
Street Scenes
Mpls. MN
RufNUSD
Copper - Posts: 184
Posted: September 05, 2004 at 12:10 AM / IP Logged
Brotherman these cars are as easy as they come. Five wire trunk? So you added a relay...aww. Isolated door triggers..welcome to the new millenium. Child safety locks...this has been going with Toyota since the early 90s and in all reality doesnt even become a burden on this car. There is always sales if this hurts too bad.
12volts
WHITE/ red
ignition harness
Starter BLACK/ white   +   ignition harness
Second Starter BLACK / YELLOW   +   ignition harness
Ignition BLACK/ red   +   ignition harness
Second Ignition BLACK / YELLOW   +   ignition harness
Third Ignition N/A
Accessory blue   +   front of fuse box
Second Accessory N/A
Keysense blue   -   ignition harness
Power Lock blue / YELLOW   -   driver kick, door harness
Power Unlock blue (double pulse)   -   driver kick, door harness
Lock Motor blue/red   5wi driver kick, door harness
Unlock Motor blue/black   5wi driver kick, door harness
Parking Lights+ green   +   bottom of fuse box
Parking Lights- red   -   headlight switch
Hazards lt. GREEN/ black   -   flasher relay in driver kick
Turn Signal(L) GREEN/ black   +   flasher relay in driver kick
Turn Signal(R) GREEN/ YELLOW   +   flasher relay in driver kick
Reverse Light RED / black   +   driver kick, harness to rear
Door Trigger see notes
Dome Supervision comes on with unlock
Trunk/Hatch Pin green   -   driver kick or light in trunk
Hood Pin black   -   theft ECU behind glove box
Trunk/Hatch Release WHITE/ blue   5wi driver kick panel
Power Sliding Door N/A
Factory Alarm Arm arms with lock
Factory Alarm Disarm disarms with unlock
Disarm No Unlock use key sense wire
Tachometer BLACK/ orange   ac   see notes
Wait to start N/A
Brake Wire GREEN / WHITE   +   brake pedal switch
Parking Brake RED / white   -   parking brake switch
Horn Trigger GREEN/ black   -   steering column
Memory Seat 1 N/A
Memory Seat 2 N/A
Memory Seat 3 N/A
Someone pass me that bottle.
