Good LOC’s?
LudeBoi
Copper - Posts: 81
Posted: February 06, 2006 at 1:04 AM / IP Logged
Are the Audio Control LC6's better than the ones PAC carries? I am not looking to spend an arm and a leg (CleanSweep). What's the best for a budget of around 100?
Ravendarat
Platinum - Posts: 2,806
Posted: February 06, 2006 at 3:57 AM / IP Logged
I would stick with the Audio control stuff. I have used 5 or 6 off their pieces before and have always been happy with the preformance I get outta them. I also never have had one fail yet.
forbidden
Platinum - Posts: 5,354
Posted: February 06, 2006 at 2:28 PM / IP Logged
Yes, use the Audio Control LC6 over a basic LOC any day of the week.
wranglercory
Copper - Posts: 53
Posted: February 08, 2006 at 10:40 AM / IP Logged
Skip the LOC and go with a aftermarket deck . I would only run a LOC if it was a last resort
kirktcashalini
Silver - Posts: 492
Posted: February 08, 2006 at 11:00 AM / IP Logged
dont listen to wrangler... Locs are a-ok. I ran them on my 99 chevy, and it sounds really nice. My friend ran them on his 04 audi, and another friend on his mazda speed 3. He had no choice because that dash is a piece that includes the radio.
as for brands... there are a million LOCs out there, ranging from 3-15 dollars. I forget what brand i shoved in my dash. but it was in the 10 range.
stevdart
Platinum - Posts: 5,816
Posted: February 08, 2006 at 12:08 PM / IP Logged
I differ on some of kirk's opinions here.  It's not the LOC itself so much as the fact that with a factory deck you have to use the high level output.  The signal is "dirtier" than a low level signal.  The voltage is higher but the signal is smaller.  One thing you'll note right away is that when you are finding the clipping point on the deck it will invariably be at about the halfway point.  (Low level signals from aftermarket decks start clipping much farther along on the volume dial.)  Setting the amp gain to that halfway point results in a smaller control sweep when you're adjusting volume.
I use LOCs in my personal car because of several reasons:  the expense of the dash kit (Taurus) and having to get rid of a good and trouble-free Clarion factory disk changer being two of them.  The overall sound is very good, but I spent a considerable amount of time and effort getting the LOC's set just right.  I twisted the LOC input wires, as well, to keep out induced noise in the wire runs from the factory wiring.
The other is the quality of LOC you should seek if you are set in keeping the factory radio.  Use only those rated as "high quality", which will start in the $20s.  It will have gain adjustments and other higher quality attributes that will enable you to get the sound quality as high as it can be.  It takes some effort;  you usually can't get best results by sticking in a $10 converter and calling it a day.
But the Audio Control device forbidden spoke of is the best way to go.
kirktcashalini
Silver - Posts: 492
Posted: February 08, 2006 at 1:36 PM / IP Logged
damn, I had typed a responce and somehow it got lost.
Well, main points...
Stedvart, you are right. Originally when I said 3-15 I did a VERY fast search for pricing (as i bought mine way back, and forget exactly what was out there).
and I must have gotten lucky, because my GM delco bose whatever head unit doesnt clip at all until it gets so loud (factory 6 locations, and sub) that i can't handle it myself. So it was never an issue of clipping for me. But definatly twist your wires, and use some sort of insulation/shielding if you can around them to be safe.
As for audiocontrol. I had a Audiocontrol 4xs crossover in the past that was amazing, and would suggest audiocontrol ANYTHING if you are willing to pay for one. they seem to be amazing pieces to me.
Tuesday, October 28, 2025 • Copyright © 1999-2025 the12volt.com, All Rights Reserved Privacy Policy & Use of Cookies
