Ignition or Accessory Wire for a 2004 BMW 745Li
dalmyd1
Member - Posts: 27
Posted: May 31, 2005 at 6:06 PM / IP Logged
Need Help ASAP.........Can anyone tell me the color & where to find either the ignition wire or the accessory wire for the above mentioned vehicle!!!!
Thanks in advance for all your assistance!!!!!!!!!
kgerry
Platinum - Posts: 3,455
Posted: May 31, 2005 at 6:17 PM / IP Logged
Ign is Green
* The 7 series has 4 ignition wires of which 2 must be connected, it is therefore recommended to connect all 4. The PURPLE acc wire may test an ignition (on during crank). If so, connect it as an extra ignition.
Kevin Gerry
MECP First Class Installer
Owner/Installer
Classic Car Audio
since 1979
Ween
Platinum - Posts: 1,368
Posted: May 31, 2005 at 6:19 PM / IP Logged
hi,
under driver dash, at connector for brake switch. ...GREEN/ black.  use it to trigger a relay to switch battery power (power socket/cig lighter).  or if you have access to a dei power adapter (55000 or 55020 can't remember), use that lead to trigger the adapter still using battery power from above location. hope this helps.
mark
