Door lock and unlock in a Ford Windstar
jorgefdz
Copper - Posts: 99
Posted: November 17, 2002 at 12:38 AM / IP Logged
Tomorrow I will conect an alarm in a Ford Windstar 1995, But  I dont understand if the door lock and unlock is positive or negative????
please help.
j.f.l.l.
egtalon93
Member - Posts: 22
Posted: November 17, 2002 at 6:17 AM / IP Logged
|       POWER LOCK|pink / YELLOW         |-  |drivers kick panel *3       |
|     POWER UNLOCK|pink/green          |-  |drivers kick panel *3       |
*3 The keyless module is behind center storage compartment.
jorgefdz
Copper - Posts: 99
Posted: November 17, 2002 at 12:47 PM / IP Logged
Only connect two wires??? no more? Im right?   I dont need to connect a third wire?
j.f.l.l.
Platinum - Posts: 12,488
Posted: November 17, 2002 at 10:33 PM / IP Logged
If the alarm requires you to choose a polarity for the third wire then you have to ground it. Otherwise if the alarm system doesn't have this, there are only two connections required.
jorgefdz
Copper - Posts: 99
Posted: November 18, 2002 at 10:43 AM / IP Logged
ok thanks.
j.f.l.l.
