2010 Ford F-150 Supercrew Alarm/Remote Start Wiring
ShaunD912
Copper - Posts: 140
Posted: February 14, 2010 at 7:51 AM / IP Logged
Could someone post the alarm and remote start wiring info for an 2010 F150 Crew Cab?
Thank You
Shaun
Platinum - Posts: 7,828
Posted: February 14, 2010 at 2:31 PM / IP Logged
 F-150 LIGHT DUTY   2009 -2010
 PART   COLOR  LOCATION  DIAGRAM
 12 VOLT CONSTANT   RED (+) (Fusible Link A AND B)    @ SJB, BLACK 1-PIN PLUG(G) PIN1, Note #2
 STARTER  BLUE/WHITE (+)   @ IGNITION SWITCH, (GRAY 10-Pin Plug), Pin 10
 STARTER 2  N/A
 IGNITION 1  WHITE/ ORANGE (+)  @ IGNITION SWITCH, (GRAY 10-Pin Plug), Pin 1
 IGNITION 2  N/A
 IGNITION 3  N/A
 ACCESSORY /HEATER BLOWER 1  PURPLE / GREEN (+)   @ IGNITION SWITCH, (GRAY 10-Pin Plug), Pin 5
 ACCESSORY /HEATER BLOWER 2  N/A
 KEYSENSE  BLUE/GRAY (+)   @ IGNITION SWITCH, (GRAY 10-Pin Plug), Pin 3
 PARKING LIGHTS ( - )  N/A
 PARKING LIGHTS ( + )  PURPLE / WHITE (+)   in DRIVERS KICK PANEL or SJB (GRAY 13-PIN PLUG(E), PIN 6, Note #2
 POWER LOCK  GRAY / YELLOW (-) TYPE (B)   in DRIVERS KICK PANEL or SJB (GRAY 26-PIN PLUG(C), PIN 17, Note #2
 POWER UNLOCK  PURPLE / GRAY (-) TYPE (B)   in DRIVERS KICK PANEL or SJB (GRAY 26-PIN PLUG(C), PIN 4, Note #2
 LOCK MOTOR WIRE  GRAY/BROWN (+) (5-wire type)   in DRIVERS KICK PANEL or SJB (BLACK 32-PIN PLUG(D), PIN 6, Note #2
 DOOR TRIGGER  GREEN/ PURPLE (-)   IN DRIVERS KICK PANEL
 DOMELIGHT SUPERVISION  GRAY/PURPLE (+)   in PASSENGER KICK PANEL or SJB (GRAY 14-PIN PLUG(A), PIN 9, Note #2
 TRUNK RELEASE  N/A
 SLIDING POWER DOOR  N/A
 HORN  BLUE/WHITE (-)   @ HORN SWITCH or SJB (BLACK 52-PIN PLUG(B), PIN 41, Note #2
 TACH  Any wire NOT BLUE (AC)   @ ANY FUEL-INJECTOR
 WAIT TO START LIGHT  N/A
 BRAKE  PURPLE / WHITE (+)   @ BRAKE SWITCH or SJB (BLACK 52-PIN PLUG(B), PIN 40, Note #2
 FACTORY ALARM DISARM   N/A
 ANTI-THEFT  FORD's Transponder Anti-theft, requires Bypass Module, See Note #1   AT IGNITION TUMBLER
NOTES
 Note #1: Transponder System, Requires Bypass Module, Part # XK04, XK05 or 791.
Note #2: the SJB (Smart Junction box) is located in the Passenger Kick Panel.
Posted: February 14, 2010 at 2:33 PM / IP Logged
2010 F150 4 Door
 Security
 WIRE  COLOR  POLARITY  LOCATION
 Battery  VIOLET/RED  (+)  IGNITION SWITCH
 Ignition 1  WHITE/ ORANGE  (+)  IGNITION SWITCH
 Starter 1  BLUE/WHITE  (+)  IGNITION SWITCH
 All Door Trigger  GRAY/VIOLET  (+)  DRIVERS KICKPANEL OR SJB CONNECTOR C2280A PIN 9
 Domelight Super  GREEN/ BLUE  (-)  DIMMER SWITCH
 Alarm Disarm  RF ONLY SEE NOTES
   IF VEHICLE HAS FACTORY ALARM THERE IS NO DISARM WIRE FOR IT CAUSE IT WORKS BY RF ONLY
 Parking Lights  VIOLET/WHITE  (+)  SJB C2280E PIN 6
Convenience
 Headlights-Lo  GREEN/ BROWN  (-)  MULTIFUNCTION SWITCH
 Seat Mem 1  VIOLET/WHITE  (-)  DRIVERS SEAT SWITCH
 Seat Mem 2  YELLOW  (-)  DRIVERS SEAT SWITCH
Remote Start
 Accessory 1  VIOLET/GREEN  (+)  IGNITION SWITCH
 Key Sense  BLUE/GRAY  (-)  IGNITION SWITCH
 Brake Lights  VIOLET/WHITE  (+)  BRAKE SWITCH
 Horn  BLUE/WHITE  (-)  STEERING COLUMN HARNESS
Doorlocks/Windows
 Door Lock Circuit  3 WIRE NEGATIVE
 Power Unlock  VIOLET/GRAY  (-)  SJB C2280C PIN 4
   IF THE VEHICLE DOESNT HAVE KEYLESS THAN ITS A 5 WIRE DOOR LOCK CIRCUIT
 PowerLock  GRAY / YELLOW  (-)  SJB C2280C PIN 17
 Driver Mtr Unlock  BLUE/GREEN  (REV)  DRIVERS KICKPANEL
 Driver Mtr Lock  GRAY/BROWN  (REV)  SJB C2280D PIN 6
 Pas Mtr Unlock  VIOLET/GRAY  (REV)  SJB C2280D PIN 27
Platinum - Posts: 12,488
Posted: February 15, 2010 at 8:59 AM / IP Logged
You can grab the 12 volts power at the DKP along with the parking lights and brake lights as well. There is a GRAY connector with these 3 wires located there. RED is the 12 volts + and the PURPLE / WHITE (x2 ) are each parking lights and brake, check with a DMM to verify connection.
gdwmson176
Posted: October 30, 2010 at 11:57 PM / IP Logged
Thanks to "kreg357" for your help with the wiring diagram for a 2010 Ford F-150 Supercrew. I was installing a power tailgate lock but the instructions that came with the lock had the wrong colors for the proper wire hook ups. With kreg357's post I was able to finish the job! Kudos to you my friend! Thanks, gdwmson176
