latching relay
theforumguy
Member - Posts: 14
Posted: August 10, 2005 at 8:47 PM / IP Logged
i need help on buying a latching relay. i need a relay the uses one - pulse to turn on and then a second - pulse to turn off. can any one help. i tired looking for one that is 12v 30amp rated but no luck, all i need is one can anyone link me to a website for this if there is one. thank you
hotwaterwizard
Silver - Posts: 1,350
Posted: August 12, 2005 at 12:16 AM / IP Logged
https://www.the12volt.com/installbay/forum_posts.asp?tid=57075&PN=2
John DeRosa (Hotwaterwizard)
Stockton California
When in doubt, try it out !
theforumguy
Member - Posts: 14
Posted: August 12, 2005 at 7:02 PM / IP Logged
thanks again
techguy688
Copper - Posts: 55
Posted: August 14, 2005 at 10:52 PM / IP Logged
All the listed latching relays are large. I would call a few of them solenoids. I continue to look for a reasonable sized single package latching relay that will handle 12vdc at around 30amps. If one of those suits your needs please let me know.  Good Luck
hotwaterwizard
Posted: August 15, 2005 at 10:18 PM / IP Logged
This one is Standard Cube Relay Size. How small do you want it?
Potter-Brumfield VPRD/S Series Relay
30 Amp Latching Relay with PC Board or Quick Connect Terminals for Automotive Applications
  • 30A continuous contact rating @ 125 degree C
  • 1 Form C arrangements
  • Plug-in or PC board terminals
  • Optional mounting bracket
  • Various enclosure options
  • Magnetically latched in both positions
  • High shock and vibration resistance
  • http://www.sourceresearch.com/potter/autorlay.cfm
    latching relay -- posted image.
    http://www.sourceresearch.com/potter/Potter-Brumfield-pdf.cfm?PdfPage=vprd_dsw.pdf
    Stockton California
    Saturday, December 27, 2025 • Copyright © 1999-2025 the12volt.com, All Rights Reserved Privacy Policy & Use of Cookies
