555F - how to install
profuse007
Gold - Posts: 2,015
Posted: November 25, 2003 at 8:23 PM / IP Logged
viper 790xv
2002 F-150 5.4L
555F
installing for my buddy tomorrow i need someone throughly explain how do i install one of these bypass. just want to know now and not have to struggle tomorrow trying to read the manual.
anything else i should be aware on this whole installation?
thanks
Houston,TX
mobiletoys2002
Gold - Posts: 1,050
Posted: November 25, 2003 at 8:32 PM / IP Logged
the 555f should be hooked up when all other things are done . before hooking up 555f make sure the car remote starts when the key is left in the ignition cylinder,if it starts go aheads and install the 555f.Remove the steerinmg columm shroud(cover).
run the wire for the pellet up toward the key cylinder leaving the pellet hanging mear the spot you put your key in.
Now take one of the ford keys and turn ignition on wait till security light goes out and remove key now take the second ford key(make sure he brings 2 working keys)and do the same thing now when you take the key out put the pellet next to the key cylinder and remote start if it starts the pellet has learned the code,if it does not start then redo everything stated above. once the pellet has learned the code you are ready to mount it so here it is take it and place it next to the antenna ring(usually a black piece of plastic that surrounds the ignition )try and start if it starts then zip tie it there.if not keep moving it in that area untill it starts (this can be tricky)
well that is about it for the transponder issue good luck.
mobiletoys2002
Gold - Posts: 1,050
Posted: November 25, 2003 at 8:39 PM / IP Logged
Also the ford has a gem that will false the door triggers every 20 mins or so so use diodes and you will be able to defeat this.
Here is how to do it find your door trigger wires cut the wire "place a diode inline with band facing door" now place another diode on the side with a band (this one goes on the one that was installed inline) now the side of the diode you just installed will have no band this is the side that will face the door trigger input of the alarm..
JWorm
Platinum - Posts: 2,208
Posted: November 25, 2003 at 8:57 PM / IP Logged
Don't these things come with directions....
mobiletoys2002
Gold - Posts: 1,050
Posted: November 25, 2003 at 9:07 PM / IP Logged
yeah they do lol555F - how to install -- posted image.
JWorm
Posted: November 25, 2003 at 9:11 PM / IP Logged
mobiletoys2002, do you work for the company that sells TSS and Maid?
mobiletoys2002
Gold - Posts: 1,050
Posted: November 25, 2003 at 9:13 PM / IP Logged
what??? I dont get that one. You can explain if you dont mind555F - how to install -- posted image.
mobiletoys2002
Gold - Posts: 1,050
Posted: November 25, 2003 at 9:37 PM / IP Logged
Damn if your refering to that software I heard that it sucked ,I never worked for any company like that. Damn that hurts.555F - how to install -- posted image.
birdondubthreez
Member - Posts: 21
Posted: November 25, 2003 at 10:03 PM / IP Logged
If the truck has 2 keys or 100 keys you will need them all to program, or the vechile will never start by rs. Also you can get the door trigger at the headlight switch it is a GREEN/ orange (-) and ithis wire will catch all doors and not false.
BiRdOnDuBtHrReEz
mobiletoys2002
Gold - Posts: 1,050
Posted: November 25, 2003 at 10:14 PM / IP Logged
you need at least the 2 masters to get programing at all.
every new car comes with these and they will be available ===if more than 2 keys were programed they are made a valet by the onboard computer in the car.
Valets are not used for programing a ford and many other makes of cars.
And while programing the 555F you want the keys not to be on the ring you need them seperate so the onboard comp dont see 2 codes at once.
I have made multiple keys for a ford and still was able to program the 555f with only the original master keys(2)
