alternator 17 volts
countdrcaula76
Member - Posts: 26
Posted: August 10, 2006 at 12:14 PM / IP Logged
hi
i have a mtx 421d amp running a kicker 05cvr12 , and i have a blaupunkt gta-470 amp running 4 speakers. my alternator gives an output of 90 A and i play my music loud . now i see my headlights dimming now and then even with the music turned of and when i measured the voltage on the battery  during the vehicle running , i got readings from 14v to even 17 volts which kept fluctuating . i kind of figure i have an alternator problem . i live in a different country and i have no HO ALTERNATORS available here i have been searching for it from a long time but havent found it yet . and i plan to add another mtx 421d amp to the current setup . so can any one help me with any information
and i checked my alternator to battery wiring it is about 1.5 cm thick so i dont know what size that is .
- saif ullah khan
countdrcaula76
Member - Posts: 26
Posted: August 10, 2006 at 12:37 PM / IP Logged
i have plenty of space to install almost any kind of alternator but the main problem is that i have  a few pipes hooked up on the back of my alternator i guees the alternator doubles as some sort of pump or something .
- saif ullah khan
countdrcaula76
Member - Posts: 26
Posted: August 10, 2006 at 12:43 PM / IP Logged
they are rubber pipes , like soemthing is getting in and and getting out back of the alternator
- saif ullah khan
countdrcaula76
Member - Posts: 26
Posted: August 10, 2006 at 12:50 PM / IP Logged
sorry it is an suv indian made . u can look at the vehicle here
http://www.mahindrascorpio.com/scorpio2006/
- saif ullah khan
KarTuneMan
Platinum - Posts: 7,056
Posted: August 10, 2006 at 1:11 PM / IP Logged
Can you not simply get a stock replacement? At 17 volts NOTHING is gonna last long.
countdrcaula76
Member - Posts: 26
Posted: August 10, 2006 at 1:46 PM / IP Logged
i can get a stock replacement but i feel that , after sometime im gonna hve the same prob with the alternator , the amps were putting a heavy load on the alternator and today i noticed that the mtx amp would keep turning on and off , when i went to the battery shope he told me the battery was  to be filled with distilled water which was nearly empty , he told me it could be an over charge problem . after that the amp dint show any prob till now .
- saif ullah khan
countdrcaula76
Member - Posts: 26
Posted: August 10, 2006 at 2:02 PM / IP Logged
ok i guess ill do that , so  is ther any alternative to the shortafe of power problem apart from a HO alternator
- saif ullah khan
countdrcaula76
Member - Posts: 26
Posted: August 11, 2006 at 7:30 AM / IP Logged
i have uploaded the pics for my alternator here . well i hope some one can helpme out
http://photos.yahoo.com/countdracula76us
- saif ullah khan
