2005 subaru baja remote start wiring
mennitti
Copper - Posts: 55
Posted: December 16, 2007 at 12:11 PM / IP Logged
Hi,
I need wiring info for a 2005 Subaru Baja.  This is for a remote start install.
Thanks.
mikvot
Gold - Posts: 1,043
Posted: December 16, 2007 at 3:02 PM / IP Logged
Subaru 2005 Baja 4DR SUV
2005 subaru baja remote start wiring - Last Post -- posted image. Remote start / security / GPS
 Wire/Function Colour Location/Description Polarity
 12 VOLTS White Ignition switch harness   +
 IGNITION Green Ignition switch harness   +
 ACCESSORY Yellow Ignition switch harness   +
 STARTER WHITE/ black Ignition switch harness   +
 KEY SENSE WHITE/ green Ignition switch harness   +
 TACH SIGNAL ORANGE / white At ECM behind glovebox   AC
 LOCK GREEN/ red At module on left of steering column   -
 UNLOCK Lt.GREEN/ YELLOW At module on left of steering column   -
 DOORPIN Pink/black At module on left of steering column   -
 BRAKESWITCH WHITE/ black At switch above brake pedal   +
 PARKLIGHTS BLACK/ white At light switch harness   -
 You must test for this wire with the ignition turned on.
 HORN RED / green At steering column   -
 VSS WIRE GREEN/ black At ECM behicle glovebox
mennitti
Copper - Posts: 55
Posted: December 16, 2007 at 3:47 PM / IP Logged
Thanks.
There is no anti-theft to bypass correct?
