2007 nissan quest
slwilson6
Member - Posts: 6
Posted: December 17, 2007 at 8:25 AM / IP Logged
Any one have the wire diagram for this one yet?  directtech, commando, nor bulldog have it on their sites yet.
teeb
mikvot
Gold - Posts: 1,043
Posted: December 17, 2007 at 4:03 PM / IP Logged
 Wire/Function Colour Location/Description Polarity
 PASSIVE ANTI-THEFT YES TRANSPONDER   SEE NOTES
 12 VOLTS Green Ignition switch harness   +
 IGNITION BLACK/ white Ignition switch harness   +
 ACCESSORY Red Ignition switch harness   +
 ACCESSORY 2 WHITE/ red Ignition switch harness   +
 STARTER BLACK/ red Ignition switch harness   +
 STARTER 2 BLACK / YELLOW Ignition switch harness   +
 KEY SENSE BLACK/ red Ignition switch harness   +
 TACH SIGNAL SEE NOTES
 Use the wire opposite of Red and Black at any of the coils on the engine.
 CRANKSHAFT POSITION SENSOR White At Crank Sensor on top left of engine   AC
 FUEL INJECTOR Opposite of Red wire At any injector on engine   AC
 LOCK Blue At module in driver's door   -
 UNLOCK Red (double pulse) At module in driver's door   -
 DOORPIN SEE NOTES
 Dome light wire is PINK at the switch on the left of the column. Separate doorpins are GRAY/RED (driver's door), WHITE/ GREEN (left sliding door) both found on the smaller of 2 white plugs on the BCM. GRAY/BLUE (front passenger door) and RED / WHITE (right sliding door) both found on the larger white plug at the BCM. The BCM (Body Control Module) is found under the driver's side dash on the left side. The wires for driver's side doors are also found in the driver's kick and the passenger side door wires in the passenger kickpanel. See the photo for details.
 TRUNK PIN Orange At BCM under driver's dash   -
 Located at the BCM under the driver's side dash on the left side.
 RIGHT SLIDING DOOR CONTROL Gray At switch in roof console   -
 TRUNK RELEASE GREEN/ red At switch in roof console   -
 FACTORY ARM Arms with lock wire
 FACTORY DISARM Disarms with unlock
 A single pulse disarms the alarm, a double pulse unlocks the doors.
 BRAKESWITCH RED / green At switch above brake pedal   +
 PARKLIGHTS RED / blue At dimmer switch control   +
 HAND BRAKE YELLOW /GREEN At base of handbrake   -
 HORN GREEN / WHITE Steering Column Harness   -
 VSS WIRE Pink/blue Behind instrument panel   AC
Available Notes
Vehicle Notes
PLEASE NOTE: This vehicle is equipped with a TRANSPONDER passive anti-theft system. Please refer to the appropriate diagram before any remote start installation.
slwilson6
Member - Posts: 6
Posted: December 17, 2007 at 4:26 PM / IP Logged
yikes, i did not know it had a pats.  do you happen to know if there is a by pass module for this van or do you have the diagram to bypass it completely?
teeb
mikvot
Gold - Posts: 1,043
Posted: December 17, 2007 at 6:41 PM / IP Logged
I use this brand of bypass. Looks like this one will take care of alot of things on that van.
http://bypasskits.fortinautoradio.com/vehicles/2007/nissan/quest/
