07 saab 93, remote start
mlweiss8503
Posted: December 17, 2007 at 9:54 AM / IP Logged
I cannot find any wiring on an 07 Saab 93 and its completely different from the 06.  What I did find said the car starts when acc drops out, but all that happens is the ignition turns on and doesn't crank. Does anyone know what it takes to get this car to start? Any info will be extremely helpful.
Cap and Hitch of New England
customak47
Copper - Posts: 164
Posted: December 17, 2007 at 6:01 PM / IP Logged
did you bypass the factory theft system? try remote starting and holding the factory key up the lock cylinder... the one I had to do was an 04 with the lock cylinder in the center console...
My rifle is my friend...
mlweiss8503
Posted: December 18, 2007 at 4:13 PM / IP Logged
i'm able to get the car to remote start with the key near the cylinder now, but i can't position the universal transponder bypass ring to work. is there a way to remove the triangular part around the key hole so i can wrap the ring around that?
mlweiss8503
Posted: December 18, 2007 at 4:19 PM / IP Logged
and other thing is when the car is running by remote starter i can't turn the key in the ignition cylinder, any ideas will be helpful. thanks
mlweiss8503
Posted: December 18, 2007 at 4:26 PM / IP Logged
i keep thinking of other issues... if anyone knows how to do and where to find door locks on this, that would help too. thanks
