03 nissan murano tach wire
Johnnynguyen20
Copper - Posts: 89
Posted: December 24, 2007 at 9:52 AM / IP Logged
Can someone tell me where is the exact tach wire is at the PCM. I removed the glove box i see at module with 2 big black plug. the bottom plug have alot of Yellow and White wires. i didn't check the top plug yet, i don't if the yellow or white tach wire is the top plug or the bottom plug. can someone please help. thanks
Johnnynguyen
Twelvoltz
Platinum - Posts: 2,384
Posted: December 24, 2007 at 10:11 AM / IP Logged
Audiovox Lists:
     Tachometer          GREY/RED          (AC)          AT COIL 1 ON THE DRIVER'S SIDE OF THE ENGINE
with this note:
ALSO AT ECM MODULE BEHIND GLOVEBOX PIN #23
Johnnynguyen20
Copper - Posts: 89
Posted: December 24, 2007 at 11:21 AM / IP Logged
i tried to use the Grey wire at the middle coil. when i program learning the tachometer wire, the system read it. PCM or ECM are the same meaning? someone posted said Yellow or White tach wire at the PCM
and you said ECM.
Twelvoltz wrote:
Audiovox Lists:
with this note:
Johnnynguyen
