97 mercedes benz e420 remote start
qdaddy
Copper - Posts: 133
Posted: December 29, 2007 at 2:21 PM / IP Logged
wire info 97 e420 benz help please
qdaddy
Copper - Posts: 133
Posted: December 29, 2007 at 5:17 PM / IP Logged
doorlock wires anyone
qdaddy
Copper - Posts: 133
Posted: December 30, 2007 at 2:48 AM / IP Logged
got the doorlock wires but is there an available bypass mod
qdaddy
Copper - Posts: 133
Posted: December 30, 2007 at 2:49 AM / IP Logged
trunk release wire?
KarTuneMan
Platinum - Posts: 7,056
Posted: December 30, 2007 at 8:47 AM / IP Logged
 12 VOLTS Red Ignition switch harness   +
 IGNITION Pink/red Ignition switch harness   +
 IGNITION 2 Pink / YELLOW Ignition switch harness   +
 ACCESSORY Pink/green Ignition switch harness   +
 STARTER Purple Ignition switch harness   +
 TACH SIGNAL Use fuel injector
 LOCK Black In passenger side kickpanel   -
 UNLOCK Blue In passenger side kickpanel   -
 DOORPIN SEE NOTES
 All 4 doors are separate circuits. BROWN / GRAY is left front, BROWN / RED is right front, BROWN / GREEN is left rear and BROWN / BLACK is right rear. All 4 wires are located at the PSE module under the rear seat on the passenger side.
 HOODPIN BROWN / red At pinswitch behind left headlight   -
 TRUNK PIN BROWN / yellow AT PSE module under rear seat   -
 TRUNK RELEASE Violet At release switch in dash   -
 FACTORY ARM Arms with lock wire
 FACTORY DISARM Disarms with unlock wire
 BRAKESWITCH BLACK/ red At switch above brake pedal   +
 PARKLIGHTS Gray/red & Gray/black At light switch harness   +
 Both wire must be used and isolated with relays.
 HEADLIGHTS
 REVERSE LIGHTS Gray / YELLOW DKP in harness to rear of vehicle   +
 DIMMER Gray/blue At any illuminated dash switch   +
 VSS WIRE GREEN/ black Radio harness   AC
qdaddy
Copper - Posts: 133
Posted: January 03, 2008 at 11:13 PM / IP Logged
thanx 4 tha reply found trunk release but locks could only find at switch one wire neg resistance but can tell me about the bypass mod needed it has a swicthblade key and dont know of a company that has bypass 4 that      thanx
Posted: January 04, 2008 at 1:47 AM / IP Logged
Forget the 1 wire, the blue and black join the floor loom just in front of driver's* seat and extending lock (Black) will close windows etc.
* Drivers seat in UK, you might have to go to passenger side. I can't think how to go-around transponder. Since you have a blade key it shouldn't be that difficult if you can find 2 transponder wires coming from ign switch you can use a 556 UW to by-pass it set for European cars.
