06 pilot tach wire
AgFrost
Posted: December 30, 2007 at 5:10 PM / IP Logged
ARGGGHHHH!!!
I cannot for the life of me find the tach wire of an 06 Honda Pilot!
Is it in that little 2 pin connector under the dash tape to a harness with blue tape?
THANKS!
Moderator - Posts: 12,488
Posted: December 30, 2007 at 7:00 PM / IP Logged
It's a black rubber 2 pin connector that's attached to the loom of wires on the driver's side strut tower. There's only one wire there in this connector. It's also got this black plastic tab that's attached to the rubber connector.
tedmond
Gold - Posts: 4,610
Posted: January 01, 2008 at 1:06 AM / IP Logged
yes, the 2 pin plug is close to drivers strut in a blue tape. the head is blocked off with a waterseal plug and only one wire is used. the connection is a tach test connector but will work just fine. take 2 min of your time and solder this connection.
AgFrost
Posted: January 01, 2008 at 3:35 PM / IP Logged
Thanks guys! I'll check for it in a little while!
AgFrost
Posted: January 05, 2008 at 1:00 PM / IP Logged
I cannot find this plug anywhere! I looked all around the master cylinder, both shock towers, the firewall and under the dash. How could this car not have it?
Posted: January 05, 2008 at 9:11 PM / IP Logged
Honda Pilot Tach Wire
Sunday, December 28, 2025 • Copyright © 1999-2025 the12volt.com, All Rights Reserved Privacy Policy & Use of Cookies
