2007 pontiac grand prix
wearly33
Member - Posts: 17
Posted: December 31, 2007 at 8:02 PM / IP Logged
I need a wiring diagram to install remote start on a 2007 Grand Prix.
W. Early
another-kelly
Silver - Posts: 618
Posted: December 31, 2007 at 8:36 PM / IP Logged
Battery          RED          (+)          AT VEHICLE FUSEBOX UNDER PASSENGER SIDE OF DASH
Ignition 1          PINK          (+)          BCM
               TWO PINK WIRES IN BCM THAT METER AS IGNITION. VERIFY THAT THE CORRECT WIRE IS BEING ENERGIZED, SLIDE THE KEY IN THE IGNITION KEY CYLINDER AND ACTIVATE REMOTE START. CORRECT WIRE IS BEING ENERGIZED IF THE KEY IN IGNITION WARNING CHIME COMES ON.
Ignition 2          WHITE          (+)          IGNITION SWITCH HARNESS OR BCM
Accessory 1          BROWN          (+)          IGNITION SWITCH HARNESS
Starter 1          YELLOW          (+)          IGNITION SWITCH HARNESS
Anti-Theft Type          GM PASSKEY IIIŪ VEHICLE IMMOBILIZER
Anti-Theft Descript          THE KEY SENDS AN RF SIGNAL TO THE BCM MODULE THROUGH AN ANTENNA LOCATED AROUND THE IGNITION CYLINDER
Key Sense          LT. GREEN          (-)          IGNITION SWITCH HARNESS
Tachometer          WHITE          (AC)          AT IGNITION CONTROL MODULE ON DRIVERS SIDE OF ENGINE
Speed Sense          DARK GREEN          (AC)          AT THROTTLE ACTUATOR MODULE ON TOP OF ENGINE
Parking Lights          WHITE          (-)          BCM C1 52 PIN BLACK PLUG PIN 10
Brake Lights          WHITE          (+)          AT BCM BEHIND DRIVERS SIDE OF DASH TO LEFT OF STEERING COLUMN     PIN #30 - THIS WIRE WILL ONLY TEST CORRECTLY WITH THE IGNITION IN THE RUN POSITION.
Reverse Lights          LT. GREEN          (+)          AT BCM BEHIND DRIVERS SIDE OF DASH TO LEFT OF STEERING COLUMN PIN #42
Horn          BLACK          (-)          AT BCM BEHIND DRIVERS SIDE OF DASH TO LEFT OF STEERING COLUMN     PIN #9
Anti Theft RX          WHITE          (+)          AT PASSKEY SENSOR IN IGNITION COLUMN
               THIS IS THE LOW VOLTAGE REFERENCE WIRE.
Anti Theft TX          BLACK          (-)          AT PASSKEY SENSOR IN IGNITION COLUMN THIS IS THE GROUND SIGNAL SENT TO THE BCM MODULE TO ENABLE THE START SEQUENCE.
Power Unlock          ORANGE / BLACK          (-)          AT BCM BEHIND DRIVERS SIDE OF DASH TO LEFT OF STEERING COLUMN C2 BLACK PLUG PIN #11
PowerLock          RED / BLACK          (-)          AT BCM BEHIND DRIVERS SIDE OF DASH TO LEFT OF STEERING COLUMN
wearly33
Member - Posts: 17
Posted: January 01, 2008 at 9:34 AM / IP Logged
Ok Thanks If I hook up a remote start only is there anything special I need to do or would it be best to go ahead and do a entire system.
W. Early
tedmond
Gold - Posts: 4,610
Posted: January 01, 2008 at 10:56 AM / IP Logged
get a bypass kit for your car.
wearly33
Member - Posts: 17
Posted: January 02, 2008 at 9:25 AM / IP Logged
Any particular one?
W. Early
tedmond
Gold - Posts: 4,610
Posted: January 02, 2008 at 10:02 AM / IP Logged
another-kelly
Silver - Posts: 618
Posted: January 02, 2008 at 10:07 AM / IP Logged
