2006 saturn ion, remote start
opj38
Member - Posts: 31
Posted: January 01, 2008 at 10:19 PM / IP Logged
I was installing a remote in this car, checked the resistor needed to bypass the Passlock system. What I did was accidently started the car with one of the passlock wires cut, now the car will not start. It will not even turn over. All the dash lites come on , but will not turn over at all. How do I reset the on board computer so it will turn over. Thanks in advance
Chris Luongo
Platinum - Posts: 3,746
Posted: January 02, 2008 at 8:23 AM / IP Logged
Reconnect the wire that was cut, and if it still won't start, leave the key in the Run position for 10 minutes, until the security light stops flashing.
Also, regardless of the dash lights coming on, check the RED / white at the keyswitch to make sure it still has constant power. It's very easy to blow the 2-amp fuse.
opj38
Member - Posts: 31
Posted: January 02, 2008 at 9:43 AM / IP Logged
thanks for the reply, tried the 10 min on, and nothing . Where is that 2 amp fuse located?
offroadzj
Gold - Posts: 2,043
Posted: January 02, 2008 at 9:00 PM / IP Logged
i know on a lot of the older style passlocks, if you get the wrong resistance, you need to just let the car sit for 10 to 15 minutes without touching anything. This will reset the key.... then just make sure everything is back together or you will have to wait another 10-15 minutes.
Kenny
Owner / Technician
KKD Garage LLC
Albany, NY 12205
opj38
Member - Posts: 31
Posted: January 02, 2008 at 9:41 PM / IP Logged
thanks aal the guys in this forum
finally find the problem 2 amp fuse [ign fuse]was blown in fuse box located drivers side panel
changed fuse it starts rightway
