2007 kia optima remote starter wiring
Home /
the12volt's Install Bay /
Vehicle Wiring Information & File Requests / 2007 kia optima remote starter wiring (
Topic Closed)
Welcome Guest :)
Posted: January 04, 2008 at 11:35 AM / IP Logged
I cannot seem to find the wiring chart for the 07 kia optima. I am looking to install a remote starter, and the only thing I can find is for the 06. Any help would be appreciated. Thanks.
Posted: January 04, 2008 at 8:39 PM / IP Logged
I would figure it not to have changed. I installed a RS for my wife in a 2006.5 Kia Optima.
here is the only info from Audiovox site
Battery RED (+) IGNITION SWITCH HARNESS
Ignition 1 WHITE/ BLUE (+) IGNITION SWITCH HARNESS
Accessory 1 WHITE (+) IGNITION SWITCH HARNESS
Starter 1 BLACK / YELLOW (+) IGNITION SWITCH HARNESS
Parking Lights BROWN / WHITE (+) AT VEHICLE LIGHT SWITCH
Brake Lights BLUE (+) AT SWITCH ABOVE BRAKE PEDAL
Power Unlock LIGHT BLUE (-) AT VEHICLE FUSE PANEL
PowerLock WHITE (-) AT VEHICLE FUSE PANEL
Trnk Release BLUE (+) IN HARNESS IN DRIVERS KICKPANEL
here is direct tech
12 Volts pink (30A) + ignition harness
Second 12 Volts orange (30A) + ignition harness
Starter green + ignition harness
Second Starter N/A
Ignition green + ignition harness
Second Ignition N/A
Third Ignition N/A
Accessory black + ignition harness
Second Accessory red + ignition harness
Third Accessory N/A
Keysense blue + ignition cylinder or BCM, 24 pin plug, pin 4
The BCM (Body Control Module) is to the left of the steering column.
Data Bus
Can Bus High
Can Bus Low
Can Bus Sw
Power Lock pink/black - driver kick or BCM, 20 pin plug, pin 3
Power Unlock brown - driver kick or BCM, 20 pin plug, pin 11
The BCM (Body Control Module) is to the left of the steering column. To unlock just the driver door, use ORANGE / black (-) at the BCM, 16 pin plug, pin 8.
Lock Motor pink/black 5 wire driver kick, door harness
Also found in the rear of the fuse box, brown 12 pin plug, pin 3.
Driver Unlock Motor red to white 5 wire driver kick, blue 20 pin plug, pin 7
Passenger Unlock Motor white 5 wire driver kick, harness to rear
Also found in the rear of the fuse box, brown 12 pin plug, pin 4.
Parking Lights (-) yellow/black - switch or BCM, 20 pin plug, pin 4
Parking Lights (+) gray (L), gray (R) + fuse box, rear brown 12 pin plug, pins 8 and 2
Hazards red + hazard switch
Turn Signal (Left) BROWN / orange + turn signal switch
Turn Signal (Right) BLACK/ orange + turn signal switch
Headlight orange - switch or BCM, 20 pin plug, pin 9
AutoLights gray - switch or BCM, 20 pin plug, pin 7
Reverse Light white + driver kick, white 14 pin plug, pin 4
Left Front Door Trigger yellow/orange - BCM, 24 pin plug, pin 22
The BCM (Body Control Module) is to the left of the steering column. Also found in the front of the fuse box, white 18 pin plug, pin 5.
Right Front Door Trigger same as left front door trigger
Left Rear Door Trigger same as left front door trigger
Right Rear Door Trigger same as left front door trigger
Dome Supervision blue - driver kick or BCM, 16 pin plug, pin 1
Trunk/Hatch Pin brown - driver kick or BCM, 24 pin plug, pin 23
Rear Glass Pin N/A
Hood Pin yellow/black - pin switch or BCM, 24 pin plug, pin 24
Trunk/Hatch Release WHITE/ black - driver kick or BCM, 20 pin plug, pin 13
Trunk Release Motor green + driver kick, blue 20 pin plug, pin 1
Also found in the rear of the fuse box, white 20 pin plug, pin 9.
Fuel Door Release brown + driver kick, harness to rear
Power Sliding Door (Left) N/A
Power Sliding Door (Right) N/A
Factory Alarm Arm green - driver kick or BCM, 20 pin plug, pin 1
Meter this wire while turning the key in the driver door key cylinder. The BCM (Body Control Module) is to the left of the steering column.
Factory Alarm Disarm orange - driver kick or BCM, 20 pin plug, pin 2
Disarm No Unlock with ignition, accessory, and key sense
Trunk Alarm Shunt red - driver kick or BCM, 20 pin plug, pin 12
Tachometer yellow/black ac driver kick, gray 33 pin plug, pin 5
Also found at the instrument cluster, 16 pin plug, pin 10.
Wait to Start N/A
Neutral Safety N/A
Clutch Pedal orange (input), BROWN / orange (output) + clutch pedal switch
Fuel Pump white + passenger kick, 14 pin plug, pin 2
Rear Defroster brown - switch or BCM, 20 pin plug, pin 18
Mirror Defroster same as rear defroster
Left Front Heated Seat pink + LF heated seat switch
Right Front Heated Seat pink + RF heated seat switch
Speed Sense gray ac data link connector, pin 6
The data link connector is under the driver side dash, below the fuse box. The VSS wire is also ORANGE / black at the BCM, 20 pin plug, pin 6. The VSS wire is also red at the amplifier, if equipped.
Brake Wire brown to red + brake pedal switch or driver kick, white 14 pin plug, pin 5
Parking Brake blue - switch or fuse box, rear brown 14 pin plug, pin 3
Horn Trigger white - horn switch or driver kick, gray 33 pin plug, pin 29
Wipers white (L), yellow (H) + windshield wiper switch
Left Front Window (Up/Down) red - blue or green A driver window switch in door
Right Front Window (Up/Down) blue - green A driver kick, door harness
Left Rear Window (Up/Down) orange - yellow A driver kick, door harness
Right Rear Window (Up/Down) gray - white A driver kick, door harness
Sun Roof (Open/Close) motor part of module
Sun Roof (Limit/Close) N/A
Memory Seat 1 N/A
Memory Seat 2 N/A
Memory Seat 3 N/A
Radio 12V pink + radio harness
Radio Ground black - radio harness
Radio Ignition pink + radio harness
Radio Illumination red + radio harness
Factory Amp Turn-on yellow/orange + radio harness
Power Antenna GREEN/ black + radio harness
Left Front Speaker (+/-) brown - white +,- radio harness or amp in pass side trunk
On models with the amplifier, there are two pairs of these wires. One pair for the tweeter and one for the woofer.
Right Front Speaker (+/-) orange - green +,- radio harness or amp in pass side trunk
Left Rear Speaker (+/-) black - yellow +,- radio harness or amp in pass side trunk
Right Rear Speaker (+/-) blue - red +,- radio harness or amp in pass side trunk
Center Channel (+/-) N/A
Subwoofer (+/-) white - brown (2 pairs) +,- amplifier in passenger side of trunk
Aux. Audio Input Left (+/-)
Aux. Audio Input Right (+/-)
RSE Video (+/-)
RSE Audio Left (+/-)
RSE Audio Right (+/-)
Satellite Radio 12 Volts
Satellite Radio Ground
Satellite Radio Ignition
Satellite Radio Antenna
Satellite Audio Left (+/-)
Satellite Audio Right (+/-)
Item Size Depth Location
Headunit double DIN center of dash
Left Front Speaker 6.5 left front door
Left Front Tweeter
Right Front Speaker 6.5 right front door
Right Front Tweeter
Left Rear Speaker 6.5 left rear door
Left Rear Tweeter
Right Rear Speaker 6.5 right rear door
Right Rear Tweeter
Center Channel
Subwoofer 8 rear deck
Left Front Headrest
Right Front Headrest
Left Rear Headrest
Right Rear Headrest
Satellite Radio Tuner
Smart Starter Kill Relay
Relay Type:
Part #:
OE Relay Part #:
n/a
n/a
n/a
Notes:
n/a
Alternate Part Notes:
n/a
Immobilizer Bypass Module
Required:
Type:
Part #:
Alternate Part #'s:
Yes
Transponder
556UW
DesignTech 20402, DesignTech 29402
Notes:
Only Canadian models have the immobilizer system.
The wire I'm test'n isn't doin' what it's supposed to be doin'... I am so glad I printed that tech sheet, with the wrong info.
Do it right the first time... or I might have to fix it for ya
Monday, March 30, 2026 • Copyright © 1999-2026 the12volt.com, All Rights Reserved • Privacy Policy & Use of Cookies
