Toyota door lock problem
stumoff
Posted: February 25, 2003 at 6:00 PM / IP Logged
My drivers door lock will not turn to un-lock. locking is fine and all other locks work normally. does anyone know of a fix rather than having to replace all locks..
Thank you.
Stu...
draasch
Gold - Posts: 2,172
Posted: February 27, 2003 at 8:47 PM / IP Logged
did it just stop working or did it go out slowly?? is the key wearing down?? try a little WD40 just a shot.the waffers in the lock are brass. they can get a little out of wack. you said the key works good in the other door? and if so then it sounds like a key problem. the drivers door wears out first because you use it more then the others.
good luck,
david
Good Luck
David
Ace Security
813-376-9778
Tampa
Donate to the 12volt
stumoff
Posted: February 28, 2003 at 9:37 AM / IP Logged
Thank u for reply.
It did happen slowly. I'm not sure if it's the key as spare key is just as bad. Maybe there both going?
I tried a bit of WD40 which seemed to make a difference at first but diddn't last. I will try again though.
Stu...
draasch
Gold - Posts: 2,172
Posted: February 28, 2003 at 10:51 AM / IP Logged
it sounds like you have a bad lock. if that key works in the other door, then your lock is OLD. might be time to replace it.
Tuesday, February 10, 2026 • Copyright © 1999-2026 the12volt.com, All Rights Reserved Privacy Policy & Use of Cookies
