viper 1002 in 05 f150/dome light issue?
barkster
Member - Posts: 20
Posted: January 13, 2008 at 4:02 PM / IP Logged
I had a Viper 1002 Alarm put in my truck by some "kids" at mobile one. After they installed it, when you closed the door and armed it, after the dome light went off the alarm would go off. Their solution to it was just to cut the dome wire. That's not a solution. I didn't realize it till I was home. I need to fix it myself since these kids have no clue what they are doing. How can I get this to work properly with this alarm and also make it turn off the dome light immediately after arming the alarm/locking doors like it did before? Any help would be appreciated.
barkster
Member - Posts: 20
Posted: January 13, 2008 at 4:11 PM / IP Logged
Here is a link to the installation manual for the alarm http://www.directeddealers.com/manuals/ig/viper/N3102V_11-06post.pdf
tedmond
Gold - Posts: 4,610
Posted: January 13, 2008 at 9:19 PM / IP Logged
the unit should have a programming option to allow dome light delay. If you double pulse the LOCK, it will turn off domelight.
barkster
Member - Posts: 20
Posted: January 13, 2008 at 9:26 PM / IP Logged
Looks like they didn't know how to program it. I'll research a bit more or bring to someone else Thanks
speed of sound
Member - Posts: 19
Posted: January 13, 2008 at 9:46 PM / IP Logged
The wiring above is for vehicles without keyless entry. Vehicles with keyless entry, the door trigger wires are found at the BCM, green plug. The LF door trigger is BLACK / YELLOW in pin 4. The RF door trigger is BLACK/ pink in pin 5. The LR door trigger is BLACK/ lt. blue in pin 12. The RR door trigger is BLACK/ white in pin 13. Use all wires and diode isolate each. The BCM (BThe wiring above is for vehicles without keyless entry. Vehicles with keyless entry, the door trigger wires are found at the BCM, green plug. The LF door trigger is BLACK / YELLOW in pin 4. The RF door trigger is BLACK/ pink in pin 5. The LR door trigger is BLACK/ lt. blue in pin 12. The RR door trigger is BLACK/ white in pin 13. Use all wires and diode isolate each. The BCM (Body Control Module) is on the driver side rear cabin wall.ody Control Module) is on the driver side rear cabin wall.
Speed of Sound Technologies
230 pershing Dr
Ansonia, CT 06401
203-954-0066
barkster
Member - Posts: 20
Posted: January 14, 2008 at 7:46 AM / IP Logged
Hey I found that wordage on a piece of paper they gave me when I was thinking of installing myself. Obviously they didn't read that. So they should have hooked up the door triggers instead of the dome or both?
