2008 nissan sentra remote start
xdrtypopx
Posted: January 17, 2008 at 11:57 AM / IP Logged
Can anyone please post information to do a Remote Start in a 2008 Nissan Sentra.  It's for my grandmother :)  Thanks!
tedmond
Gold - Posts: 4,610
Posted: January 17, 2008 at 2:50 PM / IP Logged
Battery GREEN (+) IGNITION SWITCH HARNESS Ignition 1 YELLOW (+) IGNITION SWITCH HARNESS Accessory 1 RED (+) IGNITION SWITCH HARNESS Starter 1 WHITE (+) IGNITION SWITCH HARNESS Anti-Theft Type NISSAN NVISŪ VEHICLE IMMOBILIZER Anti-Theft Descript THE KEY SENDS AN RF SIGNAL TO THE BCM MODULE THROUGH AN ANTENNA LOCATED AROUND THE IGNITION CYLINDER Key Sense RED / BLUE (+) IGNITION SWITCH HARNESS Tachometer RED (-) AT FUEL INJECTOR Speed Sense VIOLET/RED (AC) IN HARNESS UNDER CENTER CONSOLE Parking Lights RED (+) IN HARNESS IN DRIVER KICKPANEL Brake Lights RED / GREEN (+) AT SWITCH ABOVE BRAKE PEDAL Horn GREEN (-) IN HARNESS HIGH IN DRIVER KICKPANEL
tedmond
Gold - Posts: 4,610
Posted: January 17, 2008 at 2:54 PM / IP Logged
other info that you might need.
Trnk Release RED (+) IN HARNESS IN DRIVER KICKPANEL TO REAR
Alarm Disarm (-) THERE IS AN OPEN PIN IN THE KEYLESS ENTRY CONNECTOR NEXT TO THE VIOLET TRUNK RELEASE WIRE, THIS WILL DIS ARM THE FACTORY ALARM IF EQUIPPED WITH A (-) PULSE
Power Unlock PINK (-) IN HARNESS IN DRIVER KICKPANEL TO DOOR
PowerLock RED (-) IN HARNESS IN DRIVER KICKPANEL TO DOOR
