07 avalanche auto lights
kaczarcollision
Member - Posts: 10
Posted: January 18, 2008 at 10:23 PM / IP Logged
i installed a r.s. in my brothers 07 avalance and it works fine except one thing. before it was installed his automatic headlights worked fine. now when you start it manually with the key you have to manually turn them on. they work fine with remote starter? i chose to use the negative trigger at the headlight switch for the parking lights if that helps...?
disturbing the peace since 1984
stuntinonabusa
Member - Posts: 44
Posted: January 18, 2008 at 11:41 PM / IP Logged
change parking lights to positive trigger if able too...  i would always use positive tigger if available and never ran into any running light issues...
if at first u dont succeed........ lower ur standards
KarTuneMan
Platinum - Posts: 7,056
Posted: January 18, 2008 at 11:50 PM / IP Logged
Astro, and Wiremagic have NO listing for (POS)+ parking lights.
kaczarcollision
Member - Posts: 10
Posted: January 22, 2008 at 7:26 PM / IP Logged
there is positive lights under the hood. just figured it was quicker to grab the neg. at the switch. its a dual wire left right system under the hood. directtechs has it. thanks guys
