subaru wrx sti 2005 wiring
Welcome Guest :)
mixstyck
Member -
Posted: January 26, 2008 at 9:01 PM / IP Logged
I would like to know the wiring (alarm + remote starter) for a subaru wrx sti US 2005.
tedmond
Gold -
Posted: January 28, 2008 at 1:10 PM / IP Logged
| Security | | | | | | | | |
| WIRE | | COLOR | | POLARITY | | LOCATION | |
| Battery | | WHITE | | (+) | | IGNITION SWITCH HARNESS | |
| Ignition 1 | | GREEN | | (+) | | IGNITION SWITCH HARNESS | |
| Starter 1 | | WHITE/ BLACK | | (+) | | IGNITION SWITCH HARNESS | |
| All Door Trigger | | BLUE | | (-) | | AT KEYLESS ENTRY MODULE BEHIND DRIVERS SIDE DASH NEAR STEERING COLUMN | |
| Domelight Super | | BLUE | | (-) | | AT KEYLESS ENTRY MODULE BEHIND DRIVERS SIDE DASH NEAR STEERING COLUMN | |
| LF Latch | | BLUE/ORANGE | | (-) | | AT KEYLESS ENTRY MODULE BEHIND DRIVERS SIDE DASH NEAR STEERING COLUMN | |
| RF Latch | | YELLOW | | (-) | | AT KEYLESS ENTRY MODULE BEHIND DRIVERS SIDE DASH NEAR STEERING COLUMN | |
| LR Latch | | YELLOW | | (-) | | AT KEYLESS ENTRY MODULE BEHIND DRIVERS SIDE DASH NEAR STEERING COLUMN | |
| RR Latch | | YELLOW | | (-) | | AT KEYLESS ENTRY MODULE BEHIND DRIVERS SIDE DASH NEAR STEERING COLUMN | |
| Trunk Trigger | | YELLOW/RED | | (-) | | AT COURTESY LIGHT IN TRUNK | |
| Parking Lights | | VIOLET | | (+) | | AT KEYLESS ENTRY MODULE BEHIND DRIVERS SIDE DASH NEAR STEERING COLUMN | |
| | | WILL ONLY TEST WHEN THE IGNITION IS IN THE RUN POSITION. |
tedmond
Gold -
Posted: January 28, 2008 at 1:11 PM / IP Logged
| Remote Start | | | | | | | | |
| Accessory 1 | | YELLOW | | (+) | | IGNITION SWITCH HARNESS | |
| Key Sense | | WHITE/ RED | | (+) | | IGNITION SWITCH HARNESS | |
| Tachometer | | BLUE | | (AC) | | AT IGNITION COIL HARNESS UNDER HOOD | |
| Crankshaft Sensor | | GREEN | | (-) | | AT ECM CONTROL MODULE ABOVE PASSENGER KICKPANEL | |
| | | PIN #B22 | |
| Camshaft Sensor | | BLACK | | (-) | | AT ECM CONTROL MODULE ABOVE PASSENGER KICKPANEL | |
| | | PIN #10 | |
| Speed Sense | | GRAY / YELLOW | | (AC) | | AT ECM MODULE BEHIND PASSENGER SIDE OF DASH | |
| | | WILL ONLY TEST WHEN THE IGNITION IS IN THE RUN POSITION. | |
| Brake Lights | | WHITE/ BLACK | | (+) | | AT SWITCH ABOVE BRAKE PEDAL | |
| Reverse Lights | | BROWN / YELLOW | | (+) | | IN HARNESS AT LIGHT HOUSING | |
| Horn | | RED / GREEN | | (-) | | IGNITION SWITCH HARNESS |
| Power Unlock | | YELLOW/RED | | (-) | | AT KEYLESS ENTRY MODULE BEHIND DRIVERS SIDE DASH NEAR STEERING COLUMN | |
| PowerLock | | RED / WHITE | | (-) | | AT KEYLESS ENTRY MODULE BEHIND DRIVERS SIDE DASH NEAR STEERING COLUMN |
Sunday, December 28, 2025
• Copyright © 1999-2025 the12volt.com, All Rights Reserved
• Privacy Policy & Use of Cookies
