97 f150 extended cab remote start
mbrad1019
Posted: February 04, 2008 at 8:24 AM / IP Logged
Hey,
i was wondering if i could find some help with the remote start wiring. i have look at a ton of websites and they all almost say a different thing for the ignition 1,2 and 3 and the acessory. some say it has an ignition 3 some says it doesn't. if anyone could give me a link to one that is completely right it would be greatly appreciated.
thanks,
-matt
Twelvoltz
Platinum - Posts: 2,384
Posted: February 05, 2008 at 8:48 AM / IP Logged
All wiring charts are to be used only as a guide. All circuits should be verified with a DMM prior to connecting anything into them. Some vehicles do not require to have all accessories hooked up and as such some charts show accessory wires as being ignition wires to try and explain their significance. Test all the wires coming from ignition switch, hook up all the wires that test as ignition and hook up the wire that tests as the accessory wire listed as first accessory. If the blower motor or A/C compressor do not come on when remote started you need to hook up the other accessory wire(s).
Sunday, December 28, 2025 • Copyright © 1999-2025 the12volt.com, All Rights Reserved Privacy Policy & Use of Cookies
