dei 451m relay
rnemtb
Copper - Posts: 70
Posted: February 08, 2008 at 12:33 PM / IP Logged
hi,
installing a valet 562t r/s with 451m relay pack.this is going in a 99ford expedition.lost instructions for wiring 451m.does anyone have a copy of instuctions or can tell me what wires go where? (other than blue and green)this is the first time for me using this relay.
thanks
              george
rnemtb
corrysmtx
Copper - Posts: 59
Posted: February 08, 2008 at 1:36 PM / IP Logged
the wiring diagram is printed right on the back of the 451m. If you are installing a directed unit thered green and blue plug, plug straight into the doorlock output. If you are using another brand the red goes to constant 12v green goes to negative lock and blue goes to negative unlock (from the 451 small ribbon style harness).
door lock-pink / YELLOW- in the dkp
unlock-pink/light green - in the dkp
so off the 451m you will ground the violet/black wire GREEN/ black will go to the lock wire and blue/black will go to the unlock wire
You might not even need to use the 451m unless the pulses from the unit you are installing are not strong enough to power the factory locks.
1 12" mtx 9500 4ohm dvc 1 8100d and 1 1501d almost loud enough to cover the sounds of my car dying.
rnemtb
Copper - Posts: 70
Posted: February 08, 2008 at 3:37 PM / IP Logged
thanks did not see notice it was printed on relay itself.
rnemtb
corrysmtx
Copper - Posts: 59
Posted: February 08, 2008 at 10:11 PM / IP Logged
no problem glad i could help
