tweeter placement above/below mid
ctgt2005
Posted: February 16, 2008 at 6:49 PM / IP Logged
Are there any benefits/drawbacks to mounting the tweeter below the mid? The mounts  taper up and back towards the listener. If the mid were oriented above the tweeter, it would be about 4 inches closer to the listener. I can mount the drivers either way without any clearance issues. How will this affect the sound stage? The components are Focal 100Kp, the TN52 tweeter has a reputation for being slightly fatiguing.
sedate
Silver - Posts: 1,173
Posted: February 17, 2008 at 2:28 PM / IP Logged
Uhh - I don't think it matters - but move the tweeters as far away from the listener as you can.
Where are the mids mounted exactly?
sedate
Posted: February 17, 2008 at 2:30 PM / IP Logged
I'm pretty sure as long as drivers are not playing the same frequencies - they will not interfere with each other -
am I wrong? anyone?
stevdart
Platinum - Posts: 5,816
Posted: February 17, 2008 at 9:26 PM / IP Logged
The most important thing is to mount the tweeters close to the mid driver.  If there are to be pluses or minuses assigned to orientation based on "above or below", I'd venture to guess that the plus goes to the tweeter being mounted below the mid.  The tweeter's driver plane is inherently more forward than the mid driver's voice coil (because of the depth of the mid's cone), so separating it further away from your ears may equalize the planes of the two drivers a bit.  Just a small difference, parts of an inch, between planes tends to cause the mid drivers' response to drop off steeply at around the crossover point and result in deterioration in that frequency range.
Sometimes you'll have a situation where there are contours in the door panel that you may be able to take advantage of when placing the tweeter vs. mid.  If the tweeter is set back into a contour so that its driver plane is fairly even with the mid's, time alignment is better.  Placement at just a few inches above, below or to the side of the mid, in that case, is a negligible value.
Example, in my car:  Nothing flashy but the alignment is good.
tweeter placement above/below mid - Last Post -- posted image.
If I had a flat panel to work with and mounted the tweeter flush with the panel, then choosing to go below the (center of the) mid (and therefore farther away from the ear) would probably be the best choice.  But best advice is to always rig the tweeter temporarily in a few locations until you've tested for best sound.
More to read on the subject:
http://www.geocities.com/kreskovs/TimeAligned1.html
http://www.rjbaudio.com/Audiofiles/driver%20offset%20calculator.html
