wiring diagram for 2003 f150 factory ant.
joyrydn
Copper - Posts: 94
Posted: February 19, 2008 at 9:55 PM / IP Logged
i'm looking for the location/wiring route for a 2003 ford f150 factory antenna. i put in a hidden antenna and want to remove the old antenna. we shaved the antenna and the old one dropped down into the fender and i want to pull it back out. can someone help me out? i dont know where in the firewall, dash, or engine compartment it runs through. thanks in advance.
Make it Euro'n!!!
tweedg
Posted: March 03, 2008 at 7:18 AM / IP Logged
You can usually just loosen the plastic inner wheel well at the back of the fender. Take out 2 or 3 screws and you can get your hand in there. I believe the wire goes through the post in front of the door hinge. You should be able to see it with a flashlight.
joyrydn
Copper - Posts: 94
Posted: March 03, 2008 at 5:36 PM / IP Logged
thanks, i'll try that. any other input still acceptable.
Make it Euro'n!!!
Sunday, December 28, 2025 • Copyright © 1999-2025 the12volt.com, All Rights Reserved Privacy Policy & Use of Cookies
