Posted: April 28, 2008 at 4:11 AM / IP Logged
Posted: April 28, 2008 at 4:17 AM / IP Logged
Posted: April 28, 2008 at 7:49 AM / IP Logged
Posted: April 29, 2008 at 11:10 AM / IP Logged
Posted: May 02, 2008 at 11:15 PM / IP Logged
Posted: May 05, 2008 at 1:29 PM / IP Logged
Posted: May 05, 2008 at 7:23 PM / IP Logged
Wednesday, March 25, 2026 • Copyright © 1999-2026 the12volt.com, All Rights Reserved • Privacy Policy & Use of Cookies
So it just closes an internal relay contact from the battery connection to the output to the fan- I don't know what it looks like, but if it looks like you can open it up, I'd see if you could run a wire in to the coil of the internal relay and use that for switch control. I'd guess it's pretty simple to figure out, but it depends on how easy it is to open up and if you're willing to tinker with it at all. If it's all plastic welded together then just add the extra relay.
You could also use the thermo relay output to just switch the external relay coil instead of running it to the 87A contact, because the NO contacts generally handle more current than the NC ones, and it sounds like the fan draws a good amount. Lighter gauge wiring for the thermo relay could then used, but your setup probably already has the heavy wire in place, so I guess that doesn't matter now.
