'92 pathfinder stereo wire harness
fried
Posted: February 27, 2008 at 9:50 PM / IP Logged
Hi all- My ride was broken into and they took my stereo. I bought a new stereo and tried to install it but I have no power. After touching a few wires, I heard a relay clicking in my left engine compartment. All of my fuses are good. The wire harness has three separate leads. The large one plugs into the leads on my stereo harness. The middle sized one has 5 terminals, with four of them supposedly for the factory pre-amp for the rear speakers. I was told it was bypassed so I ran new wires to new rear 6 by 9's. The small plug-in I dont know what its for. Am I missing a fusebox somewhere or is it possibly I blew a relay. I was told to check the A fuse and T fuse but I dont understand that. Can anyone help?
dwarren
Posted: February 27, 2008 at 10:30 PM / IP Logged
Have you checked the fuses with the ignition switched on?
There may be two different fuse boxes in this vehicle, under the dash and under the hood.
Do you have a test light? A visual inspection of fuses can be misleading.
fried
Posted: February 29, 2008 at 9:59 PM / IP Logged
Hey Db and all- I guess I was wrong. The stereo now works in the daytime but tonight I was going to go for a ride. I fired up the stereo and everything was fine until I turned my headlights on and then the stereo went off. What the heck did I do now? I was only looking for a ground and I guess I didnt find it.
dwarren
Posted: February 29, 2008 at 11:32 PM / IP Logged
Well, you have the illumination from the vehicle as your ground. At rest or when the lights are off it will read negative but (obviously) as soon as the lights are turned on it sees voltage.
I don't believe there is a ground wire in the stock harness, you must make your own by drilling into the metal structure behind the radio.
Wednesday, April 15, 2026 • Copyright © 1999-2026 the12volt.com, All Rights Reserved Privacy Policy & Use of Cookies
