Wiring on Alpine 3319 Equalizer?
eeae6000
Member - Posts: 10
Posted: March 08, 2008 at 7:37 PM / IP Logged
Does anyone have a wiring diagram for a Alpine 7 band graphic equalizer, model number 3319, i am having problems finding one and figuring it out
Platinum - Posts: 13,726
Posted: March 08, 2008 at 8:27 PM / IP Logged
What color are the wires on the EQ?
eeae6000
Member - Posts: 10
Posted: March 08, 2008 at 9:19 PM / IP Logged
theres a group with a black wire, yellow wire, and blue wire, i know those are power, remote and ground, there is also a group with a black wire, gray wire and white wire, what are those for???
Posted: March 09, 2008 at 6:40 AM / IP Logged
Is this a preamp eq?   Does it have any din plugs on it?  If so how many?
eeae6000
Member - Posts: 10
Posted: March 10, 2008 at 7:37 PM / IP Logged
yes it is a preamp amplifier
it has 1 set of input rcas and 2 output, 1 is rear and one is for subs
Posted: March 10, 2008 at 8:48 PM / IP Logged
I am thinking that the white grey and black wires are the high level inputs.  I would not try to use them on a new radio.  This EQ was made before the high power radios of today.
eeae6000
Member - Posts: 10
Posted: March 11, 2008 at 8:52 PM / IP Logged
o but can i use this eq for subcontrol or is it a waste of time???
Posted: March 12, 2008 at 6:20 AM / IP Logged
If it has the 3 position crossover frequency selector, and a Subwoofer level control slide I can see no reason why you shouldn't at least try it.
