2001 jeep tj, remote start wiring
northernpike
Member - Posts: 7
Posted: March 09, 2008 at 9:40 PM / IP Logged
Looking for wiring schematic to install remote start on 2001 Jeep TJ Manual tranny. Thanks 2001 jeep tj, remote start wiring - Last Post -- posted image.
KarTuneMan
Platinum - Posts: 7,056
Posted: March 10, 2008 at 12:07 AM / IP Logged
What are you planning to install?
PASSIVE ANTI-THEFT
 YES TRANSPONDER   SEE NOTES
 12 VOLTS Red & Pink/black Ignition harness   +
 IGNITION Blue Ignition harness   +
 ACCESSORY BLACK/ orange Ignition harness   +
 STARTER Yellow Ignition harness   +
 KEY SENSE Lt.blue Ignition harness   -
 TACH SIGNAL Gray At coil on engine   AC
 This wire is the same for both the 2.5L and the 4.0L engines.
 FUEL INJECTOR Opposite of GREEN/ orange At any injector on engine   AC
 DOORPIN Yellow At light switch or courtesy light   -
 TRUNK PIN Common with doors
 TRUNK RELEASE Manual release
 BRAKESWITCH WHITE/ tan At switch above brake pedal   +
 PARKLIGHTS BLACK / YELLOW At light switch harness   +
 HAND BRAKE Gray/black At handbrake switch   -
 HORN RED / yellow At steering column   -
 HEADLIGHTS Lt.green or Violet/white At light switch harness   +
 REVERSE LIGHTS Violet/black In driver's kickpanel   +
 DIMMER Tan At light switch harness   +
 VSS WIRE WHITE/ orange In white plug at PCM on pass. Side firewall   AC
 DATABUS INTERFACE Pin-2(top row from left) Diagnostic plug below dash   DATA
tedmond
Gold - Posts: 4,610
Posted: March 10, 2008 at 7:06 AM / IP Logged
what remote start? make sure you got a manual safe unit or pick up the 689m from DEI. always remember safety first.
northernpike
Member - Posts: 7
Posted: March 10, 2008 at 11:27 AM / IP Logged
Thanks guys,  yes I am using one for a manual tranny,  it is a Prostart  CT-3400TW
tedmond
Gold - Posts: 4,610
Posted: March 10, 2008 at 9:13 PM / IP Logged
that is an alright unit. got one for my aunt for 70 bucks at canadian tire ! if you need help intsalling this i can help you intall it no problem.
